2 Replies Latest reply on Dec 10, 2008 12:22 PM by Newsgroup_User
    Open Image JPEG
    Almudever
      I need to open an image of external JPEG in an project. And then this one will be embedded in the project.
      My ask is: There are some Xtra appropiate to this or only lingo is sufficient? And what is the code?
        • 1. Re: Open Image JPEG
          Level 7
          You can use just Lingo. You would need to make a new bitmap member
          newMem=new(#bitmap)
          Then set the filename to your external jpg
          newMem.filename="path\to\file.jpg"
          Now, in order to "embed" it, you can make another bitmap wich has the
          same image as the one you just made, and name it.
          embeddedVersion=new(#bitmap)
          embeddedVersion.image=newMem.image
          embeddedVersion.name="WhateverNameYouWant"
          Then delete the external one if you wish
          newMem.erase()
          Then, the last step is to save the cast with the new embedded member
          castlib("internal").save()
          That's it. If you dont really need to have it saved in the castlib, you
          can get away with just setting the filename of any bitmap member. Also,
          beware that the save command does not work with compressed castlibs, so
          you can not save it in shockwave (cct) format. You can save it in cxt
          (encrypted) format.
          • 2. Re: Open Image JPEG
            Level 7
            > newMem=new(#bitmap)
            > newMem.erase()
            Alternatively:
            tMember = _movie.newMember(#bitmap)
            tMember.importFileInto("path\to\file.jpg")
