0 Replies Latest reply on Dec 10, 2008 6:47 AM by devGLGL
    AnimatorFactory in Class?
    devGLGL
      I tried to use the "Copy Motion to AS3" Command in Flash CS4 and insert the code into Flex. In included all the necessary fl classes: There is no error generated, but it just doesn't work, the MovieClip (dragMC) is not animated at all. In Flash it works without a problem.
      I also tried to create an AS Class in Flex, which I then include in Flash. The AS class in Flex contains the "Copy Motion to AS3" Code, but again it doesen't work (the rest of the code of that class works fine). I guess the question is: can the motion code be put into a class and still work? What am I missing. The example code is attached.
