0 Replies Latest reply on Nov 27, 2016 8:03 AM by carolynu42172537
    cfc oauth2 cold fusion 9
    carolynu42172537
      I am using Cold fusion 9 and have to do an oauth2 call.  I have never used cfc files - but there is example code using cfc's so I'm giving it a try (and failing) - but I don't know whether I'm failing with cfc or failing with the call.
      My application.cfc and oauth2.cfc are in the same folder...
      My application.cfc file is:
      component {
          this.name = "myApplication";
          this.applicationTimeout = CreateTimeSpan(10, 0, 0, 0); //10 days
          this.datasource = "xxxxx";
          Request.dbusername = "xxxxx";
      Request.dbpassword = "xxxxx";
      request.dsn2='xxxxxx';
      Request.key="xxxxxx";
      request.key4="xxxxxx";
      request.key8="xxxxxxxxx";
      request.dsn = 'x';
          this.sessionManagement = true;
          this.sessionTimeout = CreateTimeSpan(0, 0, 30, 0); //30 minutes
          this.customTagPaths = [ expandPath('/myAppCustomTags') ];
          this.mappings = {
              "/foo" = expandPath('/com/myCompany/foo')
          // see also: http://help.adobe.com/en_US/ColdFusion/10.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec22c24-7 50b.html
          // see also: http://help.adobe.com/en_US/ColdFusion/10.0/Developing/WSED380324-6CBE-47cb-9E5E-26B66ACA9 E81.html
          function onApplicationStart() {
              return true;
          function onSessionStart() {}
          // the target page is passed in for reference,
          // but you are not required to include it
          function onRequestStart( string targetPage ) {}
          function onRequest( string targetPage ) {
              include arguments.targetPage;
          function onRequestEnd() {}
          function onSessionEnd( struct SessionScope, struct ApplicationScope ) {}
          function onApplicationEnd( struct ApplicationScope ) {}
          function onError( any Exception, string EventName ) {}
      My oauth2.cfc file is:
      component accessors="true"
      property name="client_id";
      property name="client_secret";
      property name="authEndpoint";
      property name="accessTokenEndpoint";
      property name="redirect_uri";
      public oauth2 function init(
        required string client_id,
        required string client_secret,
        required string authEndpoint,
        required string accessTokenEndpoint,
        required string redirect_uri
        setClient_id(arguments.client_id);
        setClient_secret(arguments.client_secret);
        setAuthEndpoint(arguments.authEndpoint);
        setAccessTokenEndpoint(arguments.accessTokenEndpoint);
        setRedirect_uri(arguments.redirect_uri);
        return this;
      public string function buildRedirectToAuthURL( struct parameters={} ) {
        return getAuthEndpoint() & '?client_id=' & getClient_id() & '&redirect_uri=' & getRedirect_uri() & buildParamString(argScope = arguments.parameters);
      public struct function makeAccessTokenRequest( required string code ) {
        var stuResponse = {};
            httpService = new http();
            httpService.setMethod("post");
            httpService.setCharset("utf-8");
            httpService.setUrl(getAccessTokenEndpoint());
            httpService.addParam(type="formfield", name="client_id",   value="#getClient_id()#");
            httpService.addParam(type="formfield", name="client_secret", value="#getClient_secret()#");
            httpService.addParam(type="formfield", name="code",    value="#arguments.code#");
            httpService.addParam(type="formfield", name="redirect_uri",  value="#getRedirect_uri()#");
            result = httpService.send().getPrefix();
            if('200' == result.ResponseHeader['Status_Code']) {
             stuResponse.success = true;
             stuResponse.content = result.FileContent;
            } else {
             stuResponse.success = false;
             stuResponse.content = result.Statuscode;
           return stuResponse;
      public string function buildParamString( struct argScope={} ) {
        var strURLParam = '';
         if(structCount(arguments.argScope)) {
          for (key in arguments.argScope) {
           if(listLen(strURLParam)) {
            strURLParam = strURLParam & '&';
           strURLParam = strURLParam & lcase(key) & '=' & trim(arguments.argScope[key]);
          strURLParam = '&' & strURLParam;
        return strURLParam;
      and my test16.cfm file is:
      start
      <cfset Greeting = CreateObject("Component", "xxxxx/components/oauth2.cfc") />
      <cfset myGreeting = Greeting.getGreeting(client_secret="xxxsecretxx", authEndpoint="xxxxwhere itgoes tobeauthenticated",client_ID="xxxclient_IDXXX",accessTokenEndpoint="xxxwhereitgoesafter", redirecturi="xxxxwhereitisredirectedxxx") />
      <cfoutput>
          #myGreeting#
      </cfoutput>
      end
      It goes to start...never gets to end
      the debug message:
      16 ms16 ms1top level D:\Websites\ToolsForBusiness\disaster1\components\test16.cfm
      0 ms0 ms1CFC[ D:\Websites\ToolsForBusiness\disaster1\components\application.cfc | onError([complex value], onRequest) ] from D:\Websites\xxxxx\components\application.cfc
      0 ms0 ms1CFC[ D:\Websites\ToolsForBusiness\disaster1\components\application.cfc | onRequestStart(/components/test16.cfm) ] from D:\Websites\xxxxx\components\application.cfc
      16 ms STARTUP, PARSING, COMPILING, LOADING, & SHUTDOWN
      16 ms TOTAL EXECUTION TIME
