I moved from Windows 7 to windows 10 and now I'm unable to select any ICC profile in the print module of LR.
I've installed various ICC profiles in the file Windows/system32/spool/drivers/color
When using photoshop CS6 I've no problem selecting any of these ICC profiles in the print module while in LR they do not show up when I select others I just have the word "others" , the list of profiles is not popped-up .
Is there any other parameter to update to be able to use the color management in LR6 ?
I've un-installed and reinstalled LR but the problem is still there.
Thanks for any clue you may have
My only thought is that if these are CMYK profiles then Lightroom will not use them.
Thanks fort your answer but they are not CMYK, I used to select any of those when I was running LR6 with Windows 7 , the pb appeared with LR6 and Windows 10, quite strange
JapanWebCoated is a CMYK profile.
PAL_SECAM is a video broadcast format.
Hi, I intended to use the two others which are ICC profiles provided by Ilford to be used with the Ilford Silk paper for color prints or black and white.
