0 Replies Latest reply on Nov 29, 2016 1:10 AM by georgelivingstona
    Will action wizard supports comparing two PDF documents?
    georgelivingstona
      I am trying to compare 100+ PDF documents using action wizard. I do not find any options to set old files folder and new files folder to compare the two different PDF documents. How do the achieve comparing two PDF documents using the action wizard.
      Please find the action wizard sequence code below,
      <?xml version="1.0" encoding="UTF-8"?>
      <Workflow xmlns="http://ns.adobe.com/acrobat/workflow/2012" title="Compare" description="" majorVersion="1" minorVersion="0">
        <Sources>
        <Folder path="/C/Users/georgelivingston/Documents/A"/>
        </Sources>
        <Group label="Untitled">
        <Command name="CompareApp" pauseBefore="false"/>
        </Group>
      </Workflow>
      Please find the screenshot below after starting the action wizard for comparing the PDF documents,
      Version: Adobe Acrobat Pro DC (2015.020.20042)
      George
