• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Can't fix layout when marking several paragraphs of text
Community Beginner ,
Nov 29, 2016 Nov 29, 2016
We have experienced a problem with the possibility to mark a segment of text and do something with the layout after the latest update of InDesign (to CC2017). We use Mac at our workplace.
Before, it was possible to mark a segment of text, several paragraphs at the same time, and do stuff with the text. For instance, that the first line in every paragraph should have an indentation of 3 mm. When we do that now, all of the text disappears and is substituted with a 3.
We find that it only works when we put the cursor in the text, no text marked. So when we need to do the same thing with several paragraphs of text, we have to do the manoeuvre once for every paragraph.
Anyone else who has experienced the same problem? Found a solution? We’re crossing our fingers that this is a bug that will soon be fixed because it means quite a lot of extra work for us…
Views
841
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
I believe this has been discussed and is a known bug.
Votes
Translate
Translate
Report
Report
Community Expert ,
It's a known issue, and Adobe has indicated that they aware of it. Can you use ¶ styles in the meantime? It's a more efficient workflow for controlling paragraph formatting anyway.
InDesign CC 2017 problem with paragraph windows
Votes
Translate
Translate
Report
Report
Thanks, we use that quite often but we don’t have set styles for everything 🙂
Votes
Translate
Translate
Report
Report
Community Expert ,
Nov 30, 2016 Nov 30, 2016
Hopefully, this will be fixed soon. (Fingers crossed!)
Votes
Translate
Translate
Report
Report
Dec 20, 2016 Dec 20, 2016
Does anyone know if and when Adobe will be fixing the formatting issue described in this thread (2017 release of InDesign)? Its beyond aggravating having to select individual lines to format rather than whole chunks of text. Seems like a major bug that was overlooked on release. Maybe there is a workaround like resetting preferences? Anyone have any insight or luck with this?
Votes
Translate
Translate
Report
Report
Community Expert ,
Did you try the workarounds?
Votes
Translate
Translate
Report
Report
Community Expert ,
Did you try turning off Type Contextual Controls in Preferences > Advanced Type?
Votes
Translate
Translate
Report
Report
LATEST
Perfect. That did the trick. Thanks so much!
Votes
Translate
Translate
Report
Report
Community Expert ,
One solution could be turning on "Application Frame" under menu "Window".
Regards,
Uwe
Votes
Translate
Translate
Report
Report
Frans van der Geest (ACP):
I did try to search the forum without finding anything, no doubt because I didn’t know exactly what words to search for. But thanks to this, I could find the answer – thank you!
jane-e:
And I’m sorry about the double question, it’s my first time at this forum and it seemed to me that I had hit the wrong button and erased the first one : - ( And then I could’t find how to delete one of them.
Votes
Translate
Translate
Report
Report
Community Expert ,
You are so kind to come back and respond to both of these! You can delete or edit a comment before someone has responded to it. After that it's too late! One of us will spot it and ask a moderator to lock it down so people aren't answering in both places. We also watch for personal contact information and for spam.
Guidelines & Tips for the Adobe Forums
But the best part is that your question was answered. Welcome to the forums, and ask (or answer) anytime!
Votes
Translate
Translate
Report
Report
