1 Reply Latest reply on Dec 5, 2008 12:51 PM by rtalton
    Removing a record from an XML based datagrid
    rckehoe Level 1
      Hey... I am not sure how to remove a record from an XML based datagrid without re-loading the whole datagrid...
      I have a datgrid called contact_list, and it's data provider is set to {GetContacts.lastResult.root.contact}. I want to be able to remove a record from the list instantly. I don't care about actually deleting the record from the XML file itself...
      Is there an easy way to remove a record from a datagrid without having to reload the XML content?
      I know how to remove a record from a datagrid if the datagrid was loaded using an array... I think it's the removeItemAt function... But will this same function work for my datagrid that is loaded through an XML Object, if so... then how?
