4 Replies Latest reply on Dec 29, 2016 1:36 PM by jonathanh57056730
    Error #2038
    victoriam40501415
      I was getting the error #2038 and followed the instructions on the other forums about this problem. I cleared out the failed and task folder in my digital editions folder. When I tried to open a library ebook afterward the error message went away but now nothing happens. I tried waiting several minutes to see if the download was taking a while but nothing. If anyone has had this problem and knows how to fix it I could really use the help. thanks
        • 1. Re: Error #2038
          ko84709731
          have same problem, started yesterday. searching archives here, it starts now and then, "no one" knows why and there are never any answers or fixes.
          Personally, I think Adobe turned off one of their license servers and it's one hard-coded into the version of ADE we have. So there won't be any acknowledgement or fix - we'll have to try upgrading to see if it has any positive effect (an upgrade has been the only solution I've seen listed here in the forums and only by one user; all others never found a fix).
          • 2. Re: Error #2038
            jonathanh57056730
            I have the same problem.  When will Adobe address a fix for this issue?
            • 3. Re: Error #2038
              smithl5
              Can't open downloaded book. Error 2038, Saw a post from years ago-deleted tasks, etc., turned off AV, etc. Still won't work. When I try to add to the Library, it's only looking for epub and pdf but the downloaded file is an .acsm. Any suggestions?
              Error info:
              • 4. Re: Error #2038
                jonathanh57056730 Level 1
                Eureka!  I have a solution to those of us who could no longer download digitized ePublications onto our somewhat dated Nooks.  For the record I have a NookCOLOR,
                1. Select the available ePub book that you want from the library.  Confirm that is the book you want. A string message will appear with
                    the book title within it and will end with .acsm (which is a root file). You will also see the following message, Invalid Menu Handle.
                   Click it off and ignore this.
                2.Go to the downloads in your browser, place your cursor over the file and right click.  You will then open up a temp file and the
                   book that you want will be highlighted.  Right click again and where it says Open With, right click again that it should open with
                   the Adobe Digital Edition you are using (probably 3.0 or 3.01).
                3. Your Adobe Digital Edition will now open and the book will be downloaded. (You will actually see this happen as you did before).
                4..Connect your Nook to your computer.
                5. Click Library designation and you will see that the Nook is now on the top of all the files presented.  Using your cursor as you had done many times before, move the downloaded book onto your Nook.  Sign out of library and disconnect your Nook correctly.
                6.  Open up under My Files, Digital Editions and your downloaded book is ready for reading.
                I have done this about seven or 8 times and each time the download was successful.  I have not attempted this with any audio books but I assume that the results will be the same.
