6 Replies Latest reply on Nov 30, 2016 12:10 PM by dj_paige
    Sychronisierung von Lr CC 2015.7 [ 1090788 ] mit Lr 5.7
    klingsor1
      Salut, nach Installation von Lr CC sehe ich nicht alle "Sammlungen" und Laufwerke welche im Lr 5.7 verwendet wurden.
      Was ist zu tun??? Die aktualiserung der Kataloge habe ich bereits gemäss https://helpx.adobe.com/de/lightroom/help/create-catalogs.html
      gemacht.
      Dank für dringende Hilfe!!
        • 1. Re: Sychronisierung von Lr CC 2015.7 [ 1090788 ] mit Lr 5.7
          dj_paige Level 10
          I'm guessing that you converted the wrong catalog, are there other LR 5.7 catalog files that you can convert to LR CC?
          • 2. Re: Sychronisierung von Lr CC 2015.7 [ 1090788 ] mit Lr 5.7
            klingsor1 Level 1
            Appreciate your input and question. However I searched as per the indicated Adobe url for ".lrcat" and synchronised but it didn't work - even with "adobe chat supporters" online.
            Hence do I have not alternative to continue with 5.7 since a upgrade on Lr 6 ist not available, i.e. only CC or to purchase a Lr6 Full Version... or does anyone know how to buy an upgrade from 5.7 to 6.0???
            thanks for all help
            • 3. Re: Sychronisierung von Lr CC 2015.7 [ 1090788 ] mit Lr 5.7
              dj_paige Level 10
              If you can't get your catalog to convert properly to LR CC, then there's no point in purchasing LR 6, you will have the same problem.
              What do you mean by "synchronised"? The action you want to do isn't a synchronize, it's technically a catalog upgrade.
              • 4. Re: Sychronisierung von Lr CC 2015.7 [ 1090788 ] mit Lr 5.7
                klingsor1 Level 1
                yes, I'll refrain from the LC CC 6 trial.
                I didn't expect an "upgrade" in the continous use of the same collections/catalogues" in Lr6 but simply to continue with the same ones.
                Neither the adobe chats or phone suppoertes nor this page could help me in this issue.
                the most embarassing on this experience is that Adobe doesn't allow anymore to buy a simple upgrade from 5.6 to 6. One seems to be forced to go for the CC membership.
                • 5. Re: Sychronisierung von Lr CC 2015.7 [ 1090788 ] mit Lr 5.7
                  When you install Lightroom 6 or Lightroom CC, the new program will offer to upgrade/update the catalog. All of your previous work should still be intact in the new catalog. The new catalog is a copy of your original Lightroom 5 catalog. But a Lightroom 6/CC catalog is not backward compatible with Lightroom 5. If you want to continue using Lightroom 5 then you will have to maintain separate catalogs for the two versions.
                  • 6. Re: Sychronisierung von Lr CC 2015.7 [ 1090788 ] mit Lr 5.7
                    dj_paige Level 10
                    Of course there is an upgrade from 5.6 to 6, you are not forced to CC.
                    I still don't know what you mean by "synchronizing" the catalogs. All you have to do is upgrade the catalog, as @JimHess has pointed out.
