3 Replies Latest reply on Dec 1, 2016 2:25 PM by vangroover
    Build failure. Ideas?
    paulh43311058 Level 1
      My build failed with the following log. Any ideas?
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':transformClassesWithDexForArmv7Release'.
      > com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.111-1.b15.25.amzn1.x86_64/bin/java'' finished with non-zero exit value 137
      Build Date: 2016-11-30 17:16:14 +0000
      Configuration on demand is an incubating feature.
      null
      org.xwalk:xwalk_core_library:19+
      :preBuild UP-TO-DATE
      :preArmv7ReleaseBuild UP-TO-DATE
      :checkArmv7ReleaseManifest
      :preArmv7DebugBuild UP-TO-DATE
      :preX86DebugBuild UP-TO-DATE
      :preX86ReleaseBuild UP-TO-DATE
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:compileDebugAidl
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:generateDebugAssets UP-TO-DATE
      :CordovaLib:mergeDebugAssets
      :CordovaLib:processDebugManifest
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:compileDebugJavaWithJavacNote: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild UP-TO-DATE
      :CordovaLib:compileReleaseNdk UP-TO-DATE
      :CordovaLib:copyReleaseLint UP-TO-DATE
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:compileReleaseAidl
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:generateReleaseAssets UP-TO-DATE
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:processReleaseManifest
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:compileReleaseJavaWithJavacNote: Some input files use or override a deprecated API.
      :CordovaLib:processReleaseJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAndroidSupportSupportCompat2500Library
      :prepareComAndroidSupportSupportCoreUi2500Library
      :prepareComAndroidSupportSupportCoreUtils2500Library
      :prepareComAndroidSupportSupportFragment2500Library
      :prepareComAndroidSupportSupportMediaCompat2500Library
      :prepareComAndroidSupportSupportV42500Library
      :prepareComGoogleAndroidGmsPlayServicesAds980Library
      :prepareComGoogleAndroidGmsPlayServicesAdsLite980Library
      :prepareComGoogleAndroidGmsPlayServicesBase980Library
      :prepareComGoogleAndroidGmsPlayServicesBasement980Library
      :prepareComGoogleAndroidGmsPlayServicesClearcut980Library
      :prepareComGoogleAndroidGmsPlayServicesGass980Library
      :prepareComGoogleAndroidGmsPlayServicesGcm980Library
      :prepareComGoogleAndroidGmsPlayServicesIid980Library
      :prepareComGoogleAndroidGmsPlayServicesLocation980Library
      :prepareComGoogleAndroidGmsPlayServicesTasks980Library
      :prepareComPushwooshPushwoosh4106Library
      :prepareOrgXwalkXwalk_core_library19495145Library
      :prepareProjectCordovaLibUnspecifiedReleaseLibrary
      :prepareArmv7ReleaseDependencies
      :compileArmv7ReleaseAidl
      :compileArmv7ReleaseRenderscript
      :generateArmv7ReleaseBuildConfig
      :generateArmv7ReleaseAssets UP-TO-DATE
      :mergeArmv7ReleaseAssets
      :createXwalkCommandLineFileArmv7Release
      :generateArmv7ReleaseResValues
      :generateArmv7ReleaseResources
      :mergeArmv7ReleaseResources
      :processArmv7ReleaseManifest
      :processArmv7ReleaseResources
      :generateArmv7ReleaseSources
      :compileArmv7ReleaseJavaWithJavacNote: Some input files use or override a deprecated API.
      Note: Some input files use unchecked or unsafe operations.
      Note: Recompile with -Xlint:unchecked for details.
      :compileArmv7ReleaseNdk UP-TO-DATE
      :compileArmv7ReleaseSources
      :transformClassesWithDexForArmv7Release FAILED
      BUILD FAILED
      Total time: 49.252 secs
      * What went wrong:
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      undefined
