• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
HOWTO: Adding Graphics/Miscellaneous/Road_Map to non-HD Video
Engaged ,
Nov 30, 2016 Nov 30, 2016
PE14.1 on a WIN7 PC...
Sometime at the end of a video I add a number of photos (also using pan-and-zoom).
After last video clip & before first photo I have often inserted a Graphic (Miscellaneous)
called Road_Map into the timeline and placed a title text over this on video 2.
This has worked fine on HD videos - now I've gone back to edit some pretty old (2012!) .avi videos.
However, when I insert the same graphic into the time line I only see a small portion rather than the whole graphic as I did on the HD video:
I assume this has to do with the lower resolution of this non-HD video.  The Frame Size of the project is 720 by 576.
I have not been able to find a way to shrink the graphic - is there a way?
Views
163
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Dec 01, 2016 Dec 01, 2016
Hi Howard,
Thanks for asking question on this forum.
Please check this link: How to use Motion effect in Adobe Premiere Elements
This would help you out.
Regards,
Sandeep
Votes
Translate
Translate
Report
Report
Engaged ,
Dec 02, 2016 Dec 02, 2016
LATEST
Actually in this particular case the solution is simpler...
Because I had been working with Pan and Zoom I had turned off "Default scale to frame size" in Preferences / General.
Which meant that the Road_Map was also inserted unscaled.
The simple solution is to select the clip with the Road_Map, RMB & in the popup select Clip / Scale to Frame Size.
Votes
Translate
Translate
Report
Report
