3 Replies Latest reply on Dec 1, 2016 3:42 PM by johnrellis
    LR CC 2015.7 Not sorting by Capture Time
    magahy
      I have seen various queries in and around this topic. Mine is perhaps straightforward in the sense that it is a one camera only situation (actually I use two but each is failing to sort it's own sequence correctly). I am shooting a golf tournament and maybe have seven images in a burst. The first image or second image in the sort may be the end of the swing followed by five from the beginning. I have never seen this behaviour before, having used Lightroom continually since the original public beta.
      Reiterating that it is not a time/date sync thing between the two cameras.
      Any ideas?
        • 1. Re: LR CC 2015.7 Not sorting by Capture Time
          johnrellis Most Valuable Participant
          One possible cause that has afflicted others:  Unbelievable as it sounds, many camera manufacturers still don't record fractional seconds for capture time in photos' metadata, and LR often doesn't handle that situation very well, depending on several factors.  There are different possible workarounds, but let's first determine if that's what's going on for you.  Upload two sample pics that don't sort correctly to Dropbox (or similar) and post the sharing links here, and I can put them under the microscope.
          • 2. Re: LR CC 2015.7 Not sorting by Capture Time
            ManiacJoe Adobe Community Professional
            Without seeing the images in question, most likely this is a problem with the sub-second parsing when doing bursts of images.
            I solve this problem, and the multiple camera problem, by naming my files as yyyymmdd_hhmmss_nnnn where nnnn is the original file number. The timestamp part of the name gets me the multiple camera sync since I will not be using both cameras in the same second. The original file number gets me the correct sub-second sorting. With this format, I just sort by filename.
            When I prepare my cameras for the next event, while I am formatting the cards in the camera, I manually reset the file number back to one.
            • 3. Re: LR CC 2015.7 Not sorting by Capture Time
              I've investigated a number of instances of these symptoms, and in all of them, the cause was that the camera wasn't recording fractional seconds in the industry-standard field.  But it would be good to verify that's what is going on here.
