6 Replies Latest reply on Dec 1, 2016 6:23 AM by Bernd Alheit
    SaveAs button not working with dialogue
    idiota 1234
      I have some code I've written and links to the tools button. However the SaveAs function errors as it suggests that it is not defined. I am running this script as a folder-level script. I have pasted the script i am using below. Can anyone help me with this or suggest me on what to do?
      var Subject
      var aDocumentFileName = this.documentFileName;
      var dialog1 =
        initialize: function (dialog) {
        var todayDate = dialog.store()["date"];
        todayDate = "Date: " + util.printd("mmmm dd, yyyy", new Date());
        dialog.load({ "date": todayDate });
        commit:function (dialog) {
        var results = dialog.store();
        Subject = results["fnam"];
        aDocumentFileName = results["lnam"];
        description:
        align_children: "align_left",
        width: 350,
        height: 200,
        elements:
        type: "cluster",
        elements:
        type: "view",
        align_children: "align_row",
        elements:
        type: "static_text",
        name: "Case Reference: "
        item_id: "fnam",
        type: "edit_text",
        alignment: "align_fill",
        width: 283,
        height: 20
        type: "view",
        elements:
        name: "Save File as : "
        item_id: "lnam",
        type: "edit_text",
        width: 300,
        height: 20
        char_width: 25,
        item_id: "date"
        alignment: "align_left",
        type: "ok_cancel",
        ok_name: "Save",
        cancel_name: "Cancel"
        var myTrustedTool = app.trustedFunction(function(name)
        app.beginPriv();
        app.execDialog(name);
        app.endPriv();
      mySaveAs = app.trustPropagatorFunction(function(doc,path) {
      app.beginPriv();
      doc.saveAs(path);
      app.endPriv();
      myTrustedSpecialTaskFunc = app.trustedFunction(function(doc,path) {
      // Privileged and/or non-privileged code above
      app.beginPriv();
      mySaveAs(doc,path);
      app.endPriv();
      // Privileged and/or non-privileged code below
      if ("ok" == app.execDialog(dialog1)){
        // build file name
        var myFileName = "aDocumentFileName -" + "Subject" + ".pdf";
        // add folder name
        myFileName = "/c/documents/" + myFileName
        myTrustedSpecialTaskFunc(this, myFileName);
      app.addToolButton(
          cName: "DialogueBox3",
          cUser: "My Menu",
          cParent: "Tools",
          cLabel: "Dialogue3",
          cExec: "myTrustedTool(dialog1);",
          cEnable: "event.rc = app.doc;"
        • 1. Re: SaveAs button not working with dialogue
          The code that calls the function needs to be embedded in the file itself. When the application is first opened, and the folder-level script is executed, there are no files open, even if it was opened by double-clicking a file.
          • 2. Re: SaveAs button not working with dialogue
            idiota 1234 Level 1
            can you provide an example of this, as It is still not working for me when creating the function inside the document.
            • 3. Re: SaveAs button not working with dialogue
              What code did you put in the folder-level, and what code in the doc-level, and what happens when you open the file?
              • 4. Re: SaveAs button not working with dialogue
                idiota 1234 Level 1
                I have put this in the folder-level
                var Subject
                var dialog1 =
                  description:
                  width: 350,
                  height: 200,
                  elements:
                  type: "cluster",
                  elements:
                  type: "view",
                  elements:
                  item_id: "fnam",
                  type: "edit_text",
                  width: 283,
                  height: 20
                  type: "view",
                  elements:
                  item_id: "lnam",
                  type: "edit_text",
                  width: 300,
                  height: 20
                  char_width: 25,
                  item_id: "date"
                  type: "ok_cancel",
                  ok_name: "Save",
                  app.beginPriv();
                  app.endPriv();
                  // build file name
                  // add folder name
                  myFileName = "/c/temp/" + myFileName
                app.addToolButton(
                    cUser: "My Menu",
                    cParent: "Tools",
                I have put this in the doc-level
                app.beginPriv();
                doc.saveAs(path);
                app.endPriv();
                app.beginPriv();
                mySaveAs(doc,path);
                app.endPriv();
                When i open the document, the dialogue box appears and once i press the save. It closes the dialogue box and doesn't save.
                • 5. Re: SaveAs button not working with dialogue
                  You got it all wrong, I'm afraid. Put the dialog definition and the if-statement at the doc-level and the trusted functions and the command to add a new toolbar button at the folder-level.
                  • 6. Re: SaveAs button not working with dialogue
                    Bernd Alheit Adobe Community Professional & MVP
                    Trusted functions at doc-level makes no sense.
