Hi all,
Just so that we capture all scenarious and hardware related issues with respect to Hi DPI scaling issues in Dreamweaver on Windows, the product team requested me to make this post on their behalf.
So, if you are a person that is facing this particular issue with Dreamweaver, can you provide us with the following info?
- Your Operating System and version number
- Graphics Card on your computer and its details
- You device and version number
- Storage details (Hard Disk space, RAM)
- Version of Dreamweaver installed on your computer
Preran
Hi everyone,
Please update to the latest version of Dreamweaver 2017.0.1 where most issues with code coloring have been addressed.
See Dreamweaver 2017.0.1 is now live for more info.
This document https://helpx.adobe.com/dreamweaver/using/customize-code-coloring.html has been updated to reflect changes.
Preran
Windows 10 Pro
i7-3770
NVidia GTX 1060 6gb
16GB RAM
Samsung SSD 256GB
Seagate 3TB
Dreamweaver cc 2017.0 9314 build
Hahah... just opened the Preferences and the dialog filled all three of my monitors!
Thank you. I will share this info with the team.
Preran
Hi Micah,
Thanks for details. In case you didn't get the workaround for High DPI issues, below is the link
Thanks so much for co-operation.
Lalita
Windows 10 Pro
i7-4510 CPU @ 2.00GHz Quadcore
Intel HD Graphics
8GB RAM
Seagate 1TB 150GB Available
windows 10
hp elitebook 8440p intel
Hello, Preran​
- Windows 10 Pro 64-Bit
- Intel i7 3770
- EVGA GeForce GTX 1070 8GB RAM - Resolution 3840x2160 with 150% system DPI scaling
- 16 GB RAM
- Dreamweaver CC 2017
Hi Preran, here's my system info. Text is blurry on Dreamweaver.
- Windows 10 Pro, version 1607
- Nvidia Quadro K2200 @ 3840x2160 + 1920x1200
- HP Z440, Intel Xeon E5
- 16GB RAM, 256GB SSD + 1TB HDD
- Dreamweaver CC 2017, 9314 Build
Thanks everyone.
All of your inputs definitely going to help us in providing full High DPI support for Dreamweaver.
I would request others who are on High DPI monitors, do post your system info.
Lalita
Hi Lalita,
to add my system information as well:
Prozessor | Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz, 3301 MHz, 4 core |
Thanks for taking care about that issue.
Felix
Windows 10 Pro, x64
EVGA GeForce GTX 950
Custom build MSI Z170A MB
16GB Ram, 256GB NVMe SSD (boot), 2TB HD, 6TB External backup
Dual BenQ BL2420PT displays via DP connections
Currently using DW 2015 CC due to too many issues with 2017, including the preferences panel would span like 3 monitor widths, certain elements not lining up properly, etc. Basically making it unusable.
A note on other 2017 CC apps, Illustrator and InDesign both have a fairly large interface which is good and bad I guess. Photoshop is substantially smaller pretty much everywhere, but it's OK. Dreamweaver is the only one that gets completely borked in Windows and unusable. Now, what I don't understand is why ALL the programs aren't High DPI aware and ALL interfaces look the same (font and scale wise). There should be some pretty good consistency among all of them. I know coming from Mac there were never these issues.
Custom build PC:
Windows 10 pro 64 bit,
Gigabyte GTX 970
16GB ddr3 ram,
i5 3570k, asus p8z77-v pro
Samsung 850 pro 250GB SSD
2TB WD HDD at 7200rpm
LCD: LG Professional 27 inch 2560x1440 @ custom scaling level (133% to match 1080 ratio)
Problems that i have:
Without "disable display scaling on high DPI settings":
Everything is blurry
With "disable display scaling on high DPI settings" enabled:
1. Options menu opens in too big not visible window. (unable to use options at all).
2. Menus like "snippets" and others like that, selecting and text options are on different positions make it very hard to chose anything.
3. Find (ctrl+f) hides some of the buttons.
4. Other small issues.
Photoshop at 200% option is perfectly fine without the need to enable "disable display scaling on high DPI settings".
Windows 10 Pro, x64
Intel® Core™ i7-5500U
AMD R9-M275 4G
16GB DDR3L
1TB Hybrid SSHD
14" FHD (1920 x 1080) Display
Impossible to use Photoshop CC 2017, too big or too tiny UI. I've try all suggested ways, even using external manifest file (blurry text), nothing worked. Strangely, illustrator CC 2017 worked fined after changing scale setting in Preferences!
Too bad, I'm downgrading too.
Please let me know when there is a fix. Many thanks!
OS: Windows 10 pro v1511 build 10586.36
Graphics Card: Intel HD Graphics 515
Machine: HP Elitebook Folio G1
Processor: Intel M7-6Y75
Disk/Memory:500G SSD HD, 8GB Ram
DW: 2017 CC build 9314
Same issues here...blurry text when using at 125%, if you use compatibility setting on the .exe, it makes the file tree unusable (the collapse folder pointers do not align for example)
I have temporarily moved to Sublime with DW color scheme...I have been using DW happily for 10+ years.
Hi everyone,
Preran
Thank you everyone for sharing your platform details.
It would be great if you could also share size of your monitors, default scaling/resolution information (if not already added).
That would definitely and greatly help us achieving this milestone.
Hello, I got the same issue, but not just with DW. I have it with all Adobe apps.
My PC:
Dell Precision 5510
OS: Windows 10 Pro version 1703
OS build 15063.483
Processor Intel i7 6820HQ @ 2.7GHz
Ram 16 GB
System type 64bit
Intel HD Graphic 530 2GB
Current res 1920x1080
Dreamweaver CC (2017) 9878 build
Photoshop CC 2017.1.1 20170425.r.252 x64
Hello Folks,
We are excited to share that we have started working on Windows Hi DPI support for Dreamweaver and have already pushed a Beta build.
You would definitely like to try your hands on, so here is the link to join the program
We look forward to hear your feedback.
Lalita
Fantastic - I installed the latest beta build 10100 (after joining the pre-release program mentioned in the message above) and the hiDPI issue is much improved. System text (menus, panels, etc.) still a bit little for my liking but a VAST improvement. So pleased that this issue has been worked on.
Hi All,
Delighted to announce that DW 18.0 with Hi DPI full support for Windows is now live
