• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Preview error in slide show
New Here ,
Dec 01, 2016 Dec 01, 2016
I have 145 slide in my slide show with music. When I right click on , lets say no.120 and pick preview from here it starts at the beginning of the slide show. Yet when I click on slide 30 and right click to preview from there it works.
Views
561
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Dec 09, 2016 Dec 09, 2016
If you are not needing manual advance, avoid slideshows in Encore; do it PR.
I prefer H.264 rather than MPE2-BD.
Votes
Translate
Translate
Community Expert ,
A slideshow is limited to 99 slides. Put two slideshows in a playlist, or set the end action of slideshow 1 to slideshow 2.
It is true that CS6 added the ability to add slides beyond 99, but they are placed in the "last chapter," and I suspect this is what you are seeing. In regular playback, you are not able to use manual advance beyond slide 99 in a CS6 slideshow.
Votes
Translate
Translate
Report
Report
Guide ,
Dec 07, 2016 Dec 07, 2016
Just by way of clarification, this is a limitation of the DVD specifications & not Encore - no title is allowed more than 99 chapters.
Votes
Translate
Translate
Report
Report
New Here ,
Dec 08, 2016 Dec 08, 2016
The other problem im having is I added music to my slide show when I preview it the music is perfectly matched up with the slides.When I build the blu-ray from encore and burn the blu-ray, and play the disc in my computer the slides and music play just fine. When I play the same disc in my home blu-ray player that is attached to my TV the slide transition is different (it does the crossfade but theres  a 2sec still at the end of each slide and that throws off the timing of the music. Note - Before I added the music the slides played fine on my home Blu-ray player). Is the problem Encore or my home Blu-ray player?
Votes
Translate
Translate
Report
Report
Community Expert ,
How any slides do you have per slideshow in Encore?
What format is the audio file?
That does seem odd, and I am not sure what could cause that.
Votes
Translate
Translate
Report
Report
New Here ,
I have 186 slides and the audio format is mp3. Do you think it's better for me to do the slideshow in premiere and export or import into encore? If so what format should I use for blu-ray? I just don't understand when I play the disc in my computer it plays fine, but when I try to play it in my home Blu-ray player it messes up.
Sent from my Galaxy Tab® S2
Votes
Translate
Translate
Report
Report
Community Expert ,
I would put no more than 99 slides per slideshow, then made the end action for slideshow 1 to go to slideshow 2. You won't be able to "advance" manually to slideshow 2 (or backup from slideshow 2 to 1). It is just hard to guess how Encore is handling the last 90 slides that are placed intothe final chapter of the slideshow when you put them all in one.
Some mp3 carry info that creates issues for Encore. I would convert to wav and bring that into Encore.
I can't see how either of these issues creates the playback issue you have, however.
Votes
Translate
Translate
Report
Report
New Here ,
Is it better to do the slide show in Premiere and then IMport or export it as a movie into Encore?
If so what format should I export  it for a blu-ray.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Votes
Translate
Translate
Report
Report
