1 Reply Latest reply on Dec 2, 2016 1:42 AM by try67
    Need dropdown fields to populate checkbox (Yes, No)
    lisak51453826
      My customer has a form with a Checkbox field called "WeekendCare" With options "Yes" and "No"
      I have 8 dropdown fields (Weekend open and close times) that will need to be examined to determine whether to populate the yes/no. If ANY of the following 8 dropdown fields have a value of a time in the dropdown (other than the default "Select") - the Weekend Care gets checked "Yes"  - if none have values, then "No" is checked.
      The dropdown fields are named:
      CenterOpenSaturday
      CenterOpenSaturday2
      CenterCloseSaturday
      CenterCloseSaturday2
      CenterOpenSunday
      CenterOpenSunday2
      CenterCloseSunday
      CenterCloseSunday2
      Can you help with a javascript for this?
      And please let me know which field to place the javascript in... that is confusing sometimes.
      Thanks for your help!
        • 1. Re: Need dropdown fields to populate checkbox (Yes, No)
          Yes, this kind of operation can be quite tricky. I think the best was of doing it is to create a hidden text field and use its calculation event for this task, even if the field itself has nothing to do with it. You can use this code to achieve it:
          var dropdowns = [
              "CenterOpenSaturday", "CenterOpenSaturday2", "CenterCloseSaturday", "CenterCloseSaturday2", "CenterOpenSunday", "CenterOpenSunday2", "CenterCloseSunday", "CenterCloseSunday2"
          var tickBox = false;
          for (var i in dropdowns) {
              var f = this.getField(dropdowns[i]);
              if (f.valueAsString!=f.defaultValue) {
                  tickBox = true; break;
          this.getField("WeekendCare").checkThisBox(0, tickBox);
