Hi all
So, mathematics. This one is to tuff for me. I use this Class: http://snipplr.com/view/67582/as3-drawing-shapes-arc-burst-dashedline-gear-polygon-star-wedge-line/
To draw a polygon. I then want to position a sprite on the edge of that polygon. I would like to define the place on the polygon as a degree, so that 0 and 360 would give me the same result.
I have this script.
package
import flash.display.MovieClip;
import flash.display.Graphics;
import flash.display.Sprite;
public class Polygon extends MovieClip
private var marker:Sprite;
public function Polygon()
marker = new Sprite();
addChild(marker);
marker.graphics.beginFill(0xFF0000, .8);
marker.graphics.drawCircle(0, 0, 10);
graphics.lineStyle(3, 0x0074B9);
positionInPolygon(marker, 400, 300, 5, 200, 0, 20);
DrawingShapes.drawPolygon(graphics, 400, 300, 5, 200, 0);
public static function positionInPolygon(target:Sprite, x:Number, y:Number, sides:uint, radius:Number, angle:Number, atAngle:Number):void
if (sides <= 2)
throw ArgumentError("DrawingShapes.drawPolygon() - parameter 'sides' needs to be atleast 3");
return;
if (sides > 2)
var step:Number, start:Number, n:Number, dx:Number, dy:Number;
step = (Math.PI * 2) / sides;
start = (angle / 180) * Math.PI;
// Here I can set an integer instead of zero to jump between corners, not what I want though
target.x = x+Math.cos(start + (step * 0)) * radius;
target.y = y+Math.sin(start + (step * 0)) * radius;
I need to set target x and y differently. But how?
Let me know if it didn't make sense. I would be graceful for any help.
Jakob Wagner
Thank you for taking the time. Unfortunately, they need to be distributed evenly. I have been trying different things over the weekend and ended up with this, taking a radical different approach. It works. Have the feeling a maths expert could do it in a simpler way, though. And it would be cool if I could bevel the corners, which is going to be impossible with this approach.
Not to worry, this will do for now.
Jakob
package
...Copy link to clipboard
we need to see DrawingShapes.drawPolygon
It's on the link, but I put it below here also.
public static function drawPolygon(target:Graphics, x:Number, y:Number, sides:uint, radius:Number, angle:Number=0):void
// check that sides is sufficient to build
if (sides <= 2)
return;
if (sides > 2)
// init vars
// calculate span of sides
// calculate starting angle in radians
target.moveTo(x + (Math.cos(start) * radius), y - (Math.sin(start) * radius));
// draw the polygon
for (n = 1; n <= sides; ++n)
dx = x + Math.cos(start + (step * n)) * radius;
dy = y - Math.sin(start + (step * n)) * radius;
target.lineTo(dx, dy);
what's wrong with your marker?
Right now I can position it on each of the corners. I want a way to position it anywhere on the edge.
What I'm really trying to do is to distribute a given number of markers evenly on the edge.
// this will distribute your points equally by angle, not by distance, along the perimeter
function positionInPolygon(target: Sprite, x: Number, y: Number, sides: uint, radius: Number, angle: Number, atAngle: Number): void {
if (sides <= 2) {
//throw ArgumentError("DrawingShapes.drawPolygon() - parameter 'sides' needs to be atleast 3");
return;
if (sides > 2) {
var step: Number, start: Number, n: Number, dx: Number, dy: Number;
var stepN:Number = findStepF(atAngle,sides)
var x1:Number = x + Math.cos(start + (step *stepN)) * radius;
var y1:Number = y - Math.sin(start + (step * stepN)) * radius;
var x2:Number = x + Math.cos(start + (step * (1+stepN))) * radius;
var y2:Number = y - Math.sin(start + (step * (1+stepN))) * radius;
var x3:Number = x;
var y3:Number = y;
var x4:Number = x+50*Math.cos(atAngle*Math.PI/180);
var y4:Number = y-50*Math.sin(atAngle*Math.PI/180);
var d:Number = (x1-x2)*(y3-y4)-(y1-y2)*(x3-x4);
target.x = ((x1*y2-y1*x2)*(x3-x4)-(x1-x2)*(x3*y4-y3*x4))/d;
target.y = ((x1*y2-y1*x2)*(y3-y4)-(y1-y2)*(x3*y4-y3*x4))/d;
function findStepF(angle:Number,sides:int):int{
return Math.floor(sides*angle/360);
Jakob
package
import flash.geom.Point;
import flash.events.Event;
private var numberOfMarkers;
private var markers:Sprite;
private var offset:Number;
private var numberOfSides:int;
private var polygonAngle:Number;
numberOfMarkers = 50;
offset = 0;
numberOfSides = 3;
polygonAngle = 0;
markers = new Sprite();
addChild(markers);
for(var i:int=0;i<numberOfMarkers;i++)
var marker:Sprite = new Sprite();
markers.addChild(marker);
marker.graphics.drawCircle(0, 0, 7);
positionInPolygon(marker, 400, 300, numberOfSides, 200, polygonAngle, 360/numberOfMarkers*i);
addEventListener(Event.ENTER_FRAME, thisEnterFrame);
private function thisEnterFrame(e:Event)
offset++;
polygonAngle--;
var marker:Sprite = markers.getChildAt(i) as Sprite;
positionInPolygon(marker, 400, 300, numberOfSides, 200, polygonAngle, 360/numberOfMarkers*i+offset);
public function positionInPolygon(target:Sprite, x:Number, y:Number, sides:uint, radius:Number, angle:Number, atAngle:Number):void
if (sides <= 2)
return;
if (sides > 2)
var points:Array = [];
var step:Number, start:Number, dx:Number, dy:Number;
points[0] = new Point(x + (Math.cos(start) * radius), y - (Math.sin(start) * radius));
for (var i:int=1;i<=sides;++i)
dx = x + Math.cos(start + (step * i)) * radius;
dy = y - Math.sin(start + (step * i)) * radius;
points = new Point(dx, dy);
atAngle = atAngle%360;
// the length of each side
var sideLength:Number = 2*radius*Math.sin(Math.PI/sides);
// the length of all sides combined
var totalLength:Number = sideLength*sides;
// distance from point 0 if all sides where put in one long line
var distanceFromStart:Number = totalLength*atAngle/360;
// index of the start point
var startPoint:int = Math.floor(distanceFromStart/sideLength);
// index of the end point
var endPoint:int = startPoint==sides-1?0:startPoint+1;
// distance from the start point
var distanceFromStartPoint:Number = distanceFromStart-(sideLength*startPoint);
// difference between the to points on x, creating the side a in a right angled triangle
var a:Number = points[startPoint].x-points[endPoint].x;
// difference between the to points on y, creating the side b in a right angled triangle
var b:Number = points[startPoint].y-points[endPoint].y;
// the angle A, opposite of side a
var A:Number = Math.atan(a/b);
// the new side a based on angle A and distanceFromStartPoint
var na:Number = Math.sin(A)*distanceFromStartPoint*(b<0?1:-1);
// the new side b based on angle A and distanceFromStartPoint
var nb:Number = Math.cos(A)*distanceFromStartPoint*(b<0?1:-1);
target.x = points[startPoint].x+na;
target.y = points[startPoint].y+nb;
