• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Black boxes over text
New Here ,
Dec 02, 2016 Dec 02, 2016
I have Adobe Acrobat X Pro running on Windows 10. Some of the pdfs I open have black rectangular boxes over some text. When my co-worker opens the same doc on her computer, the boxes are not there. These are not redaction boxes- I can highlight the text, copy it and paste into word. Any ideas??
[Moved from non-technical Forum Lounge to specific Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
TOPICS
Edit and convert PDFs
Views
33.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here , Mar 07, 2021 Mar 07, 2021
I recently encountered this same problem, i.e. black boxes covering various portions of my PDF documents when I viewed them within Acrobat X Pro (with Windows 7). They were fine when viewed in the Chrome browser.
After searching for an answer, I finally just tried making random changes under "Edit Preferences" and discovered the culprit. Under "Accessibility" the box for "Replace Document Colors" was checked (I don't know why, but maybe I'm at fault), and when I unchecked the box the problem was
Votes
Translate
Translate
Adobe Employee ,
Dec 04, 2016 Dec 04, 2016
Hi evand85701,
Could you please try following steps and see if that  resolve the issue:
1- Check for updates, launch Acrobat>navigate to help menu>select Check for Updates. If there is an update available, download and install it and then relaunch Acrobat.
2- If that doesn't work, select Edit menu>Preferences>Page Display>Rendering>Smooth Text>select None from the drop down options>OK
3- Relaunch Acrobat.
Let me know the version of Acrobat X installed on the computer?
Votes
Translate
Translate
Report
Report
New Here ,
Thank you for your response
1- No updates available
2- Didn't work
I am running Acrobat X Pro version 10.1.16.
I am enclosing a sample of what i see, with text highlighted, It should be
noted that when I print out this page, it comes out normal.
Also when I open the same document with Adobe Reader, the problem does not
occur.
Thanks for your help- I am pretty dumbfounded by this.
Evan
Votes
Translate
Translate
Report
Report
New Here ,
Jul 24, 2020 Jul 24, 2020
I'm having the same issue with certain documents sent from a particular vendor.  I tried the steps given above with no success.  I'm using Adobe Acrobat Pro 9.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hi Kstrode
We are sorry to hear that. As described yu are using Acrobat 9 Pro and experiencing some issues.
Adobe Acrobat 9 pro is an old and Eol application and problems are expected to appear with such an old version of the application. Please upgrade to the latest version of Adobe Acrobat Pro DC. By upgrading installations to the latest versions, customers benefit from the latest functional enhancements and improved security measures.
For more information please take a look at the help page https://helpx.adobe.com/acrobat/kb/end-support-acrobat-8-reader.html
Regards
Amal
Votes
Translate
Translate
Report
Report
New Here ,
Aug 18, 2021 Aug 18, 2021
I use Adobe Acrobat DC and when I redact and apply redactions, I get black boxes at the bottom of the page where I have not redacted.  This redacts mostly white space, but there is a last line with identifying information at the bottom of the page that is also redacted.  When I remove the black box, which is a pain because on a large document it takes a long time to complete this task) it also removes this one line of text.
Votes
Translate
Translate
Report
Report
LEGEND ,
Is your coworker using Acrobat X?
Have you checked
Adobe products and Enterprise Technical Support
periods covered under the new Lifecycle Policy
For the expiration of support for Acrobat/Reader X?
It look like support for Acrobat/Reader X ended November 15, 2015. It might be time to consider updating.
It might be some preference setting. Are the PDFs you looking at forms?
If so check the field highlighting.
Votes
Translate
Translate
Report
Report
New Here ,
After searching for an answer, I finally just tried making random changes under "Edit Preferences" and discovered the culprit. Under "Accessibility" the box for "Replace Document Colors" was checked (I don't know why, but maybe I'm at fault), and when I unchecked the box the problem was solved.
It appears that the boxes were generally in places where there was some kind of colored shading, and apparently the colors were being replaced by pure black which rendered the text in those areas entirely obscured.
What a relief!
Robert Winters
Cambridge, MA
Votes
Translate
Translate
Report
Report
New Here ,
Mar 14, 2022 Mar 14, 2022
LATEST
I was having the same issue on fillable forms and updated my version of DC to 2022.001.20085 on Windows 10, and the issue is now fixed. I had to go into task manager & kill all open/ruuning Adobe programs even after I closed them because it would not finish the install without it.
Votes
Translate
Translate
Report
Report
