5 Replies Latest reply on Dec 9, 2016 9:09 AM by Stivushka
    ComboBox Used to Change Frames
    Stivushka
      I have a couple of programs where a ComboBox is used to change frames.  Mostly it works okay but if the ComboBox is held open and the mouse pointer is moved back and forwards repeatedly over the options (sort of thing you do when Debugging) I get the error:
      ypeError: Error #1009: Cannot access a property or method of a null object reference.
        at fl.controls::ComboBox/close()
        at fl.controls::ComboBox/onListItemUp()
      This only happens on ComboBoxes where the options are used to change frames.  An example of the code i use is below
      CalcCombo.addEventListener(Event.CHANGE, CalcSelectPage);
      function CalcSelectPage (event:Event):void
        if (CalcCombo.selectedItem.label == "FLOW") {
        gotoAndStop(3);
        else if (CalcCombo.selectedItem.label == "EFFICIENCY") {
        gotoAndStop(4);
        else if (CalcCombo.selectedItem.label == "POWER") {
        gotoAndStop(2);
      Does anybody know whats going on?
