Lightroom 5.7.1 Mac OS 10.12.1
The filmstrip is not showing properly. All of the and the slide does not appear. And the "pointer DOES NOT change to a verticle double-arrow cursor. It is not possible to adjust the size of the filmstrip.
Studying Adobe Photoshop Lightroom 3, Classroom in a Book. and have done a search and found no solution.
13-inch MacBook Pro with Retina display
3.0GHz Dual-core Intel Core i7
16GB 1600MHz DDR3L SDRAM
1TB Flash Storage
APPLE THUNDERBOLT DISPLAY-USA
27-inch
It should be "All of the slide does not appear. I can not see to the edge of the slide and cannot see the edit symbols.
Also on the toll bar the icon for 2 displays is no longer visible.
Nothing has been added.
Did you install any add on app to adjust the text size or screen resolution?
You said "All of the and". What word did you leave out.
See if the solutions offered in this bug report help: Filmstrip is covering / overlapping filter- and breadcrumb bar | Photoshop Family Customer Community
That worked. It was a bit of a hassle because I had to enter the serial numbers from version 3 and version 5. Then restart Lightroom and then select File > Open Catalog and open the previously created catalog "LR3CIB Library Catalog.lrcat' which is Lightroom 3 classroom in a book which I have been using.
However, Many thanks. Yesterday I tried removing what I thought were the preference files, but I didn't have the correct file. This seem to for great.
