4 Replies Latest reply on Jan 18, 2017 3:09 PM by Kevin-Monahan
    Sharpen effect increases brightness instead of sharpening
    Garret2628
      I'm having a strange issue when applying the Sharpen effect to footage.  As I increase the slider the brightness of the image increases with no change in the sharpness.  Visually it looks the same as applying the Curves effect and pulling the white point to the left.  I've tried it in several projects, including a new blank one with the same result.  Happens on any type of layer, solids included.  I've cleared my cache, trashed preferences and checked the plugin folder to make sure there wasn't something weird happening there and it all looks fine.  No other effect seems to have a problem.  I've added some images as an example.  The Sharpen effect is applied to the bottom and set to 30.  Any ideas on why this is happening?  I'm using 14.0.1 on El Capitan.
