5 Replies Latest reply on Dec 5, 2016 10:18 AM by Roei Tzoref
    need 6480 px by 1920 px in MP4 format
    Lindaholiner Level 1
      Not sure if this question has been asked before. I need to create an MP4 file that is 6480 by 1920 pixels. I can create the file in After Effects but when I go to convert the file to MP4 in Media Encoder, the file is resized to 4096 by 1212 pixels. Is there any way I can get the dimensions I need in MP4  format? Thanks.
        • 1. Re: need 6480 px by 1920 px in MP4 format
          H.264 – MP4 has standard frame sizes.
          H.264/MPEG-4 AVC - Wikipedia
          You may be able to force that frame size using different  software but don't expect it to be 100% successful all the time.
          If you have some kind of a playback system that is demanding that frame size I need to check into their specifications of him and coding technique because it is not standard. It would help if we knew why you need that exact frame size.
          • 2. Re: need 6480 px by 1920 px in MP4 format
            The client uses several projectors that project onto that screen size. That is what they told us we need.
            • 3. Re: need 6480 px by 1920 px in MP4 format
              Roei Tzoref Adobe Community Professional
              you try the H.265 HEVC codec. High Efficiency Video Coding - Wikipedia it will create an mp4 container and the maximum resolution is 8192×4320.
              • 4. Re: need 6480 px by 1920 px in MP4 format
                Sorry about the second paragraph I posted above. -- Voice to text on my phone.
                As I stated and Roei reenforced you'll need a special container. AE and the Media Encoder won't allow you to do this so you'll have to render to a mezzanine codec (production format digital intermediate) that will accept this format and then use 3rd party solutions to render using another format like h.264. Contact your client and ask them what they use to encode and then use that.
                • 5. Re: need 6480 px by 1920 px in MP4 format
                  as Rick mentioned - this is not a standard file size. in my experience, the projectors have a limit for projecting the video say HD Projectors are common, 4K maybe no so much - and you actually need more than that. The setup is carefully placed HD projectors in an overlapping setup so that you can project as many pixels as you want by producing as much video files as needed for each segment. so 10xHD video in overlapping can produce +10k projection for example
                  as for the encoding, just to be clear, you can encode H.265 in AME and it works fine. I have not used that codec personally but exporting in the dimensions OP specified passes through and the file plays using VLC Player.
                  so ask your client exactly how is this going to play and what exactly do you need to give him. if it's one mp4 file in the resolution you specified - you can.
