Does anyone know if the generate speech functionality supports SSML - I have searched all the usual sources and can't find anything. Thanks.
[Title updated to fix typo. — Mod.]
Interesting question, so I tried a few commands. I got it to run a sub alias correctly (I think) but other commands it appears to ignore completely. Perhaps the developers would like to comment on this?
I was able to paste in many of the SSML XML examples and have them work on Windows 7 with "Microsoft Anna" as the voice.
Use SSML to Create Prompts and Control TTS (Microsoft Speech Platform)
Things that didn't work were things like <prosidy> but I would suspect that more recent voices like those from Windows 10 (e.g. "Microsoft David Desktop") might work better.
So I believe it works, and if something doesn't it is likely to be a combination of the OS as well as how the particular voice is implemented. We simply just pass the blob of text (either raw text or SSML) to the OS's TTS engine.
What sort of work are you doing that you need or are familiar with SSML? Thanks for using the Generate Speech effect in Audition.
