6 Replies Latest reply on Dec 6, 2016 10:59 AM by jasonjam
    Sensor Animation
    jasonjam Level 1
      Hello,
      I'm hoping someone can guide me on the best way to animate an adaptive cruise control sensor.
      Please take a look at this 3-D video for the animation reference- Adaptive Cruise Control Audi - YouTube
      The final animation won't be in 3-D.
      I need to animate the bars from the attached reference.
      Thanks.
        • 1. Re: Sensor Animation
          Effects --> Generate --> Radio Waves and a bit of masking and pre-comping.
          Mylenium
          • 2. Re: Sensor Animation
            jasonjam Level 1
            Cool. This might work. Can you help me on how do rotate the radio wave so looks like my graphic? I can't seem to figure that out.
            • 3. Re: Sensor Animation
              No need to rotate anything. Just set a suitably low side count on the polygon shape or create a rectangular mask with the right orientation and feed it into the effect. Of course you can always rotate the pre-comp layer just as well, since you will have to mask it anyway.
              Mylenium
              • 4. Re: Sensor Animation
                jasonjam Level 1
                That is starting to look like what I need but the pulse starts from the middle. I need the pulse to start from right to left. Attached is a shot of my desktop.
                • 5. Re: Sensor Animation
                  You can move the producer point, can you not? You need to spend some time with the plug-in and learn how it works. Even if the producer point was static, you could still pre-compose the whole layer and mask it, so only one side remains, which is what I would do, anyway - create a large square comp, tweak the wave parameters, use the pre-comp as a layer in the parent comp and mask out the "cone" using a mask or a symetrrical radial wipe. And again, that also takes care of any alignment and orientation issues because you can simply rotate and move the layer as a whole.
                  Mylenium
                  • 6. Re: Sensor Animation
                    jasonjam Level 1
                    Thanks for responding and all your help! I got it looking good.
