0 Replies Latest reply on Dec 5, 2016 8:17 AM by cuelliam
    Indesign CS6 prints half of each page
    cuelliam Level 1
      I've been using inDesign since the beginning and have never before encountered this problem. I have an a simple indesign text document which I need to proofread. Pages are 6x9 and I'd like to print 2 pages on each 8.5x11 sheet. Ideally that would be in printer spreads, but I'm willing to accept just reader spreads.
      I've worked for the last 6 hours, trying every single thing I can think of: including creating a new document from scratch with placeholder text, printing from a pdf of the document, updating ppd, resetting the printer, restarting computer, using a different computer, setting up a new printer, spreadson/spreads off, booklet/no booklet, and every configuration of the print dialog box that I know, and I cannot get it to print correctly. The preview in the print dialog box looks good, but doesn't represent what comes out of the printer.
      I get either 4 pages per sheet or a single page with exactly half the first page beside half of the second page.
      I've attached the print summary for my latest test, as well as a screenshot illustrating what comes out of the printer. I'm pretty sure I've done everything possible, but is there anything I could have missed?
      PRINT SUMMARY
      Print Preset: [Custom]
      Printer: HP Color LaserJet Pro M252dw (B9B98C)
      PPD: HP Color LaserJet Pro M252dw
      PPD File: /var/folders/q6/n45tqnhx58z0s0_7509v8qzc0000gn/T//5845887484d31
      General
          Copies: 1
          Collate: N/A
          Reverse Order: Off
          Pages: All
          Sequence: All Pages
          Spreads: Off
          Print Master Pages: Off
          Print Layers: Visible & Printable Layers
          Print Non-printing Objects: Off
          Print Blank Pages: Off
          Print Visible Guides and Baseline Grids: Off
      Setup
          Paper Size: US Letter
          Paper Width: 8.5 in
          Paper Height: 11 in
          Page Orientation: Landscape
          Paper Offset: N/A
          Paper Gap: N/A
          Transverse: N/A
          Scaling: Scale To Fit
          Constrain Proportions: N/A
          Page Position: Centered
          Thumbnails: Off
          Tiling: Off
      Marks and Bleed
          Crop Marks: Off
          Bleed Marks: Off
          Registration Marks: Off
          Color Bars: Off
          Page Information: Off
          Printer Mark Type: Default
          Crop Mark Weight: 0.25 pt
          Mark Offset from Page: 0.0833 in
          Use Document Bleed Settings: On
          Bleed Top: 0 in
          Bleed Bottom: 0 in
          Bleed Inside: 0 in
          Bleed Outside: 0 in
          Include Slug Area: Off
      Output
          Color: Composite RGB
          Text As Black: Off
          Trapping: N/A
          Flip: None
          Negative: N/A
          Screening: Default
          Simulate Overprint: Off
      Graphics
          Send Data: Optimized Subsampling
          Download: Complete
          Download PPD Fonts: On
          PostScript®: Level 3
          Data Format: ASCII
      Color Management
          Document Profile: sRGB IEC61966-2.1
          Color Handling: Let InDesign Determine Colors
          Printer Profile: Document RGB - sRGB IEC61966-2.1
          Preserve RGB Numbers: Off
          Proof Profile: N/A
          Simulate Paper Color: N/A
      Advanced
          Print &as Bitmap: N/A
          Bitmap Resolution: N/A
          OPI Image Replacement: Off
          EPS: Off
          PDF: Off
          Bitmap Images: Off
          Transparency Flattener Preset: [Medium Resolution]
          Ignore Spread Overrides: Off
