• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Tool Bar Buttons
New Here ,
May 19, 2006 May 19, 2006
Hi, the default tool bar in Robohelp isn't what I want and I would like to remove some buttons and change the ordering of their display. I can't figure out how to do this. Can anyone tell me how to do this? Thanks. Becky.
Views
613
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
Hi Becky and welcome to the forum!
What type of output are you producing? .chm? WebHelp? FlashHelp? JavaHelp? Other?
When we know the answer to that question, someone on the forum should be able to give you an answer.
Anne
Votes
Translate
Translate
Report
Report
New Here ,
WebHelp. Thanks.
Votes
Translate
Translate
Report
Report
Community Expert ,
May 22, 2006 May 22, 2006
In RH HTML you cannot change the toolbar regardless of what you are outputting.
I believe the same is true of the RH toolbars that appear in Word when used with RH for Word.
Votes
Translate
Translate
Report
Report
Guest
Hi Becky,
Just to be clear about what you mean by the "default tool bar", which buttons do you want to remove or change the order of?
(Peter, I'm not ignoring your reply, but there might be some confusion in the terminology. Becky might be referring to the TOC, Index, Search, etc. buttons.)
Anne
Votes
Translate
Translate
Report
Report
Community Expert ,
Good point Anne. I'm struggling to get back into work mode!
Votes
Translate
Translate
Report
Report
New Here ,
May 23, 2006 May 23, 2006
I'd like to move the About button to the far left, and remove one of the search buttons. It sounds like it can't be done. Major design flaw - I hope they change this when Robohelp becomes Flare or whatever.
Votes
Translate
Translate
Report
Report
Guest
Hi Becky,
Have you looked at RoboWizard's website? Click this link to go to the site, download the Skinny on Skins file. You will find all sorts of useful information in there about skinned webhelp. Not sure about changing the position of the About button, but you can certainly banish one or both search buttons.
Post back if you can't find what you're looking for.
Anne
Votes
Translate
Translate
Report
Report
New Here ,
May 26, 2006 May 26, 2006
Becky,
I would suggest that you find a file called "whstart.js" in your webhelp output folder. Look for the following line:
var gsToolbarOrder = "toc|idx|fts|blankblock|banner";
Modify that line to read:
var gsToolbarOrder = "banner|toc|idx|fts|blankblock";
The about image should now appear on the left-hand side. I haven't looked into how to adjust the relative positioning, but I'm sure it is just a matter of making additional modifications to another file. Also, I suspect that you can make your changes permanent for all future projects/builds by modifying the source files (RoboHelp program files directory). I've done this with the caption of the About box. I hope that this helps.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
LATEST
Yup, as documented in the Skinny on Skins file referenced by AuthorAnne yesterday in her third reply!
Votes
Translate
Translate
Report
Report
Guest
If I am understanding you correctly Becky, this is built right into the UI. Take a look at this: http://www.adobe.com/go/rb_44972 .
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Hi ~LivingProof~
Ahhh if only it were that easy. There are simply certain things that one must climb under the RoboHood and tweak in order to get them like you want them to be. In Becky's case, this is the way it is. The UI will indeed allow you to turn certain buttons off or on and even rearrange their positioning. But the "About" button isn't one of those items.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
