3 Replies Latest reply on Dec 6, 2016 1:15 PM by briank99751229
    Error! Check activation
    gailzakay
      I am trying to download a book from Overdrive, I was getting error 2038 but when I updated ADE to version 4.5.2 I am now getting Error! Check Activation.  Can someone help me with this
        • 1. Re: Error! Check activation
          Nanaky Level 5
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
          • 2. Re: Error! Check activation
            gailzakay Level 1
            Thank you so much, it worked!
            • 3. Re: Error! Check activation
              briank99751229 Level 1
              I have done all of the above BUT NOW CANNOT AUTHORIZE!!!!  The software says it cannot "connect to activation server" and thinks I am not online...  Obviously I AM online as evidenced by this post.
              PLEASE HELP!
