Is there any way to recreate "go to next/previous state" in a custom advanced or shared action? I need to be able to trigger variable changes off the commands, but they aren't in the dropdown menus for standard or conditional actions.
Thought about it and solved the problem by digging in the CPM.js file and finding the jscript that controls the go to next state and go to previous state actions.
(NOTE: I did give up on using an "on click" entry as found in InDesign or Animate since it seemed like it might be incompatible with Captivate)
Let's use an object with 5 states as an example.
To bring the object up on entry in a state that allows both buttons to work on entry create the following advanced action:
Change State of <object
...Copy link to clipboard
Change State of <object name> to <state name>
(if I wanted to have the object start with an equal number of clicks for previous and next state command, I would select the state name assigned to the second new state I created.)
Assign <variable> with <literal>
(in order to make the conditional sync up with the current view on entry, this number would be 3 - the midpoint of the variable value range)
Here's the conditional action for "Go To Next State" that will disable the "Next State" button when it reaches the last state created:
IF
<variable> is not equal to <literal>
(for example, if the object had 5 states, and you create the variable with a value of 1 - the literal number here would be 5, as each click will increment the value by 1 as shown below)
THEN
Execute JavaScript 'cp.goToNextState("object name");cp.actionChoicePauseMovie();' in current window
Increment V <variable> by 1
Enable <Go To Previous State Button name>
ELSE
Disable <Go To Next State Button name>
and here's the conditional action for "Go To Previous State" that will disable the "Previous State" button when it reaches the object's default state:
IF
<variable> is not equal to 1
(the variable is created and assigned a value 1 - therefore the default state will occur when the value reaches 1)
THEN
Execute JavaScript 'cp.goToPreviousState("object name");cp.actionChoicePauseMovie();' in current window
Decrement <variable> by 1
Enable <Go To Next State Button name>
ELSE
Disable <Go To Previous State Button name>
the actions above prohibit the states from cycling. The states can go from default through intermediate to last state (1, 2 3, 4, 5), last through all intermediate to default (5, 4, 3, 2, 1) and back and forth infinitely within this series selecting the buttons associated with the actions, but cannot switch directly from 5 to 1 (4, 5,1) or from 1 to 5 (2, 1, 5) as the standard advanced action allows.
The variable value can also be used to more than simple state changes. It can trigger feedback or open/close branched activities based on the selections made by simply adding i to the IF and ELSE lines as needed.
