• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
(Help) Problem aligning shapes to make a 3d object
New Here ,
Dec 06, 2016 Dec 06, 2016
Is there any decent way to align shapes to make a 3d object to avoid those annoying gaps between them?
I've tried setting the layer mode to Aplha Add like in this video but it doesn't make any difference.
https://greyscalegorilla.com/tutorials/how-to-align-3d-layers-perfectly-in-after-effects/
Instead of squares I'm using retangulars shapes (on After Effects CC)
Views
182
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Dec 06, 2016 Dec 06, 2016
There isn't and for the most part the tutorial is simply typical Greyscalegorilla nonsense. Alpha Add doesn't fix anything with the 3D renderer. It still applies the edge filtering. There can of course be situations where the placment of the camera, the size of the solids in relation to the comp size and the positioning of the 3D layers make it appear like there is no edge degeneration because the antialaising of two layers adds up in a way that it matches exact 100% pixel opacity, but unlike th
Votes
Translate
Translate
LEGEND ,
There isn't and for the most part the tutorial is simply typical Greyscalegorilla nonsense. Alpha Add doesn't fix anything with the 3D renderer. It still applies the edge filtering. There can of course be situations where the placment of the camera, the size of the solids in relation to the comp size and the positioning of the 3D layers make it appear like there is no edge degeneration because the antialaising of two layers adds up in a way that it matches exact 100% pixel opacity, but unlike the "tutorial" suggests, this is nothing you can forcibly control in every situation. It's merely coincidental and at the latest, even if the layer appear to be tight, it will crop up again when you turn on shadows. Only real contiguous 3D geometry and a suitable renderer can avoid this.
Mylenium
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
That's bad =(
Thank you for the response!
Votes
Translate
Translate
Report
Report
