• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
RoboHelp 2015 lag issues
New Here ,
Dec 06, 2016 Dec 06, 2016
Ever since upgrading from RH 11 to RH 2015 we've been experiencing awful lag issues. Everything from opening topics to typing has a second or two lag which is unbearable after a while, and is costing us valuable man hours.
I contacted Adobe customer support. The representative took over my computer and tried to fix the issue himself. He couldn't. He said it was an issue with my project, but couldn't tell me what the issue actually was. There were no such lag issues in RH11, so I'm wondering how this can be the fault of my project and not of RH 2015.
I've seen other discussion posts about RH 2015 lag issues, but the only response I've seen to those is to run the project locally on your machine. I am doing this and I still get the lag issues constantly. How can I fix this lag?
Edition: RH 2015
Version: 12.0.4.460
Project size: 200+ topics
Windows 10 Pro
RAM: 16GB
i7-6650U CPU @ 2.20 GHz
TortoiseSVN 1.9.4 - Used to version our help and keep it synced with the software, but the project is checked out locally to my machine. When I update the project in RH 2015 I then update the main project through SVN. (Again, we used this same exact setup with RH11 and it worked like a charm.)
Thank you for your time.
Views
353
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Hi there
Oh how fun. Don't you love troubleshooting?
I think I I were in your shoes, I'd begin by simply closing the project you are in and creating a new empty project. Add a few topics. See if the lag still exists after playing with it for a while. If so, you know it's got something to do with RoboHelp and your setup. And if there seems to be no lag, my own suspicion is something to do with the fact source control is in the mix. At that point, further troubleshooting would be in order.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Community Expert ,
... or try one of the sample projects that ship with RoboHelp.
Votes
Translate
Translate
Report
Report
New Here ,
There is no lag when creating or working on a new blank project. The Adobe support person tried that when they worked on my computer. Sorry, should've mentioned that.
We do not have the option of not using source control (SVN) with our help so I hope that's not the issue. If that's the case why would RH11 work great with SVN and RH 2015 does not?
What other troubleshooting can I try?
Votes
Translate
Translate
Report
Report
New Here ,
Dec 07, 2016 Dec 07, 2016
Any other ideas on how to troubleshoot this situation?
Votes
Translate
Translate
Report
Report
Community Expert ,
Dec 11, 2016 Dec 11, 2016
LATEST
I assume that you didn't also change operating system, etc when you upgraded to RH2015? If you did, perhaps you need to check you have 32-/64-bit versions of (sorry, mental blank) the api/dll/thingy that RH uses to talk to SVN. ( Just a thought experiment, so may be completely irrelevant. The thing I'm thinking of is specifically for TFS - the MSSCCI Provider, but possibly there is a similar thing for SVN).
Or anther thing to check is your antivirus. Many years ago I had problems with very slow check-in/out and it turned out to be the antivirus scanning every file multiple times. The solution was to make sure the AV only scanned once, rather than on both actions - I think it was only scan on check-out, but possibly vice versa.
Votes
Translate
Translate
Report
Report
Participant ,
Hi!
I'm not a  specialist for your question, but I might be able to provide some more reference information. I'm using RH 2015 with TortoiseSVN on Windows 7, 8 GB RAM, also with several large projects (size +1000 topics). I don't have any lag issues, neither when opening a project nor when typing or saving. So I don't think it's a general problem of using version control and RH 2015. More likely your problem is caused by a mix of several issues.
Kind regards
Karin
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
