I have 2 event names "Talk" and "Adele C Reserve which are the names of an event and displayed on the web site which are typed in by the client.
If i add the name of the event i wish to go to with "-"'s, it goes to the correct page and displays using the correct template
<div class="search-result">
<h3>{{counter}}. <a href="/event-pricing/adele-c-reserve">{{name}}</a></h3>
<p>{{description}}</p>
</div>
However the name keyed in by the client does not have the "-" so if i put in
<h3>{{counter}}. <a href="/event-pricing/{{name}}">{{name}}</a></h3>
This works for names that do not have any spaces "Talk" but if the name has spaces "Adele C reserve" it does not
I am trying to replace the spaces in the tag {{name}} with "-" with the following code. Not being that familiar with liquid and lack of information on BC on how to impliment liquid I am stuck.
<h3>{{counter}}. <a href="/event-pricing/{{'-" " will be replaced.' | replace: ' ', 'string' }}{{name}}">{{name}}</a></h3> |
Can anyone point me in the right direction?
Thanks Liam
That does not quite work in this case as I need to use the Event list template and {{url}} uses the Event detail template. I have modified the booking module extensively with the help of BCGurus to give variable pricing.
I eventually got it to work with
<a href="/event-pricing/{{name | replace: ' ', '-' }}">{{name}}</a> |
The event-pricing is a web app, in order for the path to work any name with spaces needed the space substituted with '-' and when I put in {{name}} alone I just had the s
...Copy link to clipboard
Is this a webapp?
If it is you just use {{url}} and do not need to do any of that
If it is an event, events do not have an SEO friendly url and you would again use the event URL.
Just trying to get a grasp of the core thing your trying to do first to establish if you even need to do any of the above at all.
Thanks Liam
The event-pricing is a web app, in order for the path to work any name with spaces needed the space substituted with '-' and when I put in {{name}} alone I just had the spaces and no link. ie /event-pricing/Adele C option (not working) became /event-pricing/Adele-C-option (working).
Thanks for the response I have another issue I will use the {{url}} to fix
Got you, Following those guides..
To much to go into and its what I get paid to build here but linking an event to a webapp is so much simpler to do and even more powerful then that lot know
