4 Replies Latest reply on Dec 14, 2016 8:14 AM by Günter Heißenbüttel
    Editing the menu
    Treffenberg Level 1
      Hello!
      I would like to edit the menu and add vertical lines between the menu words.
      Can anyone help me with this please?!
        • 1. Re: Editing the menu
          Günter Heißenbüttel Adobe Community Professional
          Very simple to do!
          Test it as follows:
          Method 1:
          • Create a new site, add some pages an place a standard horizontal menu.
          • Select the whole menu (In the upper left corner of your application window you see the label "Menu").
          • Go to the "Fill" command in the upper control strip and choose the black color.
          • You now have filled the menu background and you can see this background colour in the "gaps" between the single menu entries.
          • To customize the width of this gap, open the "Spacing" panel and use the "Gutter" command to widen or narrow the gap (= line)
          Method 2:
          • Klick onto the menu, until one menu entry is selected (In the upper left corner of your application window you see the label "Menu item").
          • Now klick onto the orange word "Stroke" in the upper control strip. Select the option to only draw one stroke (left, right, bottom, top) and choose the "weight". Choose a colour from the colour selector right to the word "Stroke". Attention: You have to configure this for every single menu state.
          • 2. Re: Editing the menu
            Treffenberg Level 1
            Hello Mac!
            Thank you very much for the solution to my problem!
            Best regards,
            Carl
            • 3. Re: Editing the menu
              Treffenberg Level 1
              Hello Mac!
              I have a page on my website with all our recordings.
              I would like to be able to klick on one of the recordings and get a pop-up window with a picture of the album sleeve and some info.
              Is it easy to do this? I have tryed for some hours now but can not find a solution.
              Do you have the time to help me?
              • 4. Re: Editing the menu
                This is not really "easy to do", but possible:
                Pure Text links can be associated to links to other pages, but not to pop up windows.
                The only way to achieve this would be using a composition widget with an according number of triggers: The triggers contain the text, the targets the album sleeve and additional infos.
                Once formatted one trigger, the rest is nothing but a routine piece of work.
