• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Convert selection to work path.
Participant ,
Dec 07, 2016 Dec 07, 2016
I've used a script listener to record the action but once copied across I can't get it to work,
I get the error Functionality may not be available. line 63
What could be the issue?
Or is the another workaround to getting the object to have an "auto"path?
The image is in 3 layers
Main Image
BACKGROUND
Original Image (invisible)
#target "photoshop"
var idslct = charIDToTypeID( "slct" );
    var desc77 = new ActionDescriptor();
    var idnull = charIDToTypeID( "null" );
        var ref37 = new ActionReference();
        var idmagicWandTool = stringIDToTypeID( "magicWandTool" );
        ref37.putClass( idmagicWandTool );
    desc77.putReference( idnull, ref37 );
    var iddontRecord = stringIDToTypeID( "dontRecord" );
    desc77.putBoolean( iddontRecord, true );
    var idforceNotify = stringIDToTypeID( "forceNotify" );
    desc77.putBoolean( idforceNotify, true );
executeAction( idslct, desc77, DialogModes.NO );
var idsetd = charIDToTypeID( "setd" );
    var desc78 = new ActionDescriptor();
        var ref38 = new ActionReference();
        var idChnl = charIDToTypeID( "Chnl" );
        var idfsel = charIDToTypeID( "fsel" );
        ref38.putProperty( idChnl, idfsel );
    desc78.putReference( idnull, ref38 );
    var idT = charIDToTypeID( "T   " );
        var desc79 = new ActionDescriptor();
        var idHrzn = charIDToTypeID( "Hrzn" );
        var idPxl = charIDToTypeID( "#Pxl" );
        desc79.putUnitDouble( idHrzn, idPxl, 17.000000 );
        var idVrtc = charIDToTypeID( "Vrtc" );
        desc79.putUnitDouble( idVrtc, idPxl, 17.000000 );
    var idPnt = charIDToTypeID( "Pnt " );
    desc78.putObject( idT, idPnt, desc79 );
    var idTlrn = charIDToTypeID( "Tlrn" );
    desc78.putInteger( idTlrn, 2 );
    var idMrgd = charIDToTypeID( "Mrgd" );
    desc78.putBoolean( idMrgd, true );
    var idAntA = charIDToTypeID( "AntA" );
    desc78.putBoolean( idAntA, true );
executeAction( idsetd, desc78, DialogModes.NO );
var idInvs = charIDToTypeID( "Invs" );
executeAction( idInvs, undefined, DialogModes.NO );
var idmodalStateChanged = stringIDToTypeID( "modalStateChanged" );
    var desc80 = new ActionDescriptor();
    var idLvl = charIDToTypeID( "Lvl " );
    desc80.putInteger( idLvl, 1 );
    var idStte = charIDToTypeID( "Stte" );
    var identer = stringIDToTypeID( "enter" );
    desc80.putEnumerated( idStte, idStte, identer );
    var idkcanDispatchWhileModal = stringIDToTypeID( "kcanDispatchWhileModal" );
    desc80.putBoolean( idkcanDispatchWhileModal, true );
executeAction( idmodalStateChanged, desc80, DialogModes.NO );
    var desc81 = new ActionDescriptor();
    desc81.putInteger( idLvl, 0 );
    var idexit = stringIDToTypeID( "exit" );
    desc81.putEnumerated( idStte, idStte, idexit );
    desc81.putBoolean( idkcanDispatchWhileModal, true );
executeAction( idmodalStateChanged, desc81, DialogModes.NO );
var idMk = charIDToTypeID( "Mk  " );
    var desc82 = new ActionDescriptor();
        var ref39 = new ActionReference();
        var idPath = charIDToTypeID( "Path" );
        ref39.putClass( idPath );
    desc82.putReference( idnull, ref39 );
    var idFrom = charIDToTypeID( "From" );
        var ref40 = new ActionReference();
        var idcsel = charIDToTypeID( "csel" );
        ref40.putProperty( idcsel, idfsel );
    desc82.putReference( idFrom, ref40 );
    desc82.putUnitDouble( idTlrn, idPxl, 0.500000 );
executeAction( idMk, desc82, DialogModes.NO );
TOPICS
Actions and scripting
Views
666
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Dec 07, 2016 Dec 07, 2016
When you use the scriptlistener plugin it records everything it can that you do in Photoshop.  Sometimes you do not want all it records you just want some of what has been recorded.  I find I do step for it to record that I need to set up conditions so what I want it to record can be recorded.  Therefore extra things are recorded, I have to delete what I do not want  The the stuff I do not want mad not even work in me script because conditions are not right for the step so it will not be availab
Votes
Translate
Translate
Adobe
Community Expert ,
When you use the scriptlistener plugin it records everything it can that you do in Photoshop.  Sometimes you do not want all it records you just want some of what has been recorded.  I find I do step for it to record that I need to set up conditions so what I want it to record can be recorded.  Therefore extra things are recorded, I have to delete what I do not want  The the stuff I do not want mad not even work in me script because conditions are not right for the step so it will not be available. Often I find I do not want some of the modalstatechanhe yje are recorded.  Try to make sense of what is recorded use the required steps.
JJMack
Votes
Translate
Translate
Report
Report
Participant ,
I've just gone through it again step by step making sure that I didn't do anything that was note required. but have worked out that the second last 2 blocks were not needed.
Many thanks
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
I use windows I control what the scriptlistener record by comtrolling the script log file readonly attribite.  I use a BAT file to do that. It a windows that give you a choice of things to do the the log file.  Lock, UnLock, Edit, Clear or end close the window.
       @Echo Off
:loop
        CLS
rem Display Log File Size
        Dir "%USERPROFILE%\Desktop\ScriptingListenerJS.log" /T:W /4 | find "%ScriptingListenerJS.log"
rem Display Log Attributes  R read only Locked no R log is Unlocked
        Attrib "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
Rem If timeout is use the above display lines will refresh over time else you need to use enter or number
        CHOICE /C 123456 /N /T 300 /D 6 /M "Enter:1 to Lock, 2 to Unlock, 3 to Edit, 4 to Clear, 5 To Exit :"
        Echo %ERRORLEVEL%
        if %ERRORLEVEL%==6 goto timeout
        if %ERRORLEVEL%==1 goto one
        if %ERRORLEVEL%==2 goto two
        if %ERRORLEVEL%==3 goto three
        if %ERRORLEVEL%==4 goto four
        if %ERRORLEVEL%==5 goto five goto loop
:timeout
        goto loop
:one
        Attrib +R "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
       goto loop
:two
        Attrib -R "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
        goto loop
:three
        Rem inline command use CMD independate command use start
        CMD /C notepad "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
rem Start notepad "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
        goto loop
:four
        Rem If the script log file is unlocked not read only  this echo will clear it
        Echo. > "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
        goto loop
:five
         EXIT
JJMack
Votes
Translate
Translate
Report
Report
