I have applied tracking data to the positions of both clone brush stroke and clone source and then used an expression to offset the tracking data and return the stroke and clone source point to the original position in order to remove an object from the composition.
First attempt (including a line break):
thisComp.layer("
tracker").transform.position-[3027-1615.5, 1509-1663.5]
Result: "Error: Unterminated String Constant"
Second attempt (deleted line break):
thisComp.layer("tracker").transform.position-[3027-1615.5, 1509-1663.5]
Result: "Error: Layer named "tracker" is missing or does not exist" (but it definitely does, and is named properly)
I tried a semi-colon ";" at the end of the line. No luck.
Third attempt:
deltaX = 3027 - 1615.5;
deltaY = 1509 - 1663.5;
x = thisComp.layer("tracker").transform.position[0];
y = thisComp.layer("tracker").transform.position[1];
[x-deltaX, y-deltaY];
Why is it telling me the layer doesn't exit when it does? Is this a bug or am I doing something incorrectly? I am using AE CC 2017. Is there a way to fix the error, or do I need to find a new method to use the clone stamp with tracking data?
Renaming did not work. This appears to be a bug in AE. The way around it when this happens is to open up a new project.
Rename your null layer to something like TrackInfo and try pick whipping to that.
Hey Greg,
Did Szalam's response help you solve your issue?
Kevin
