I have multiple indesign files in a multiple folder, is there any script which creates idml as output for those indesgn files at same location where its indd file is located
Hi Maja,
thank you for the notification.
I changed my post above to the new working link.
Regards,
Uwe Laubender
( ACP )
See here:
Batch-process (convert/export/import) documents
by Peter Kahrel
https://creativepro.com/files/kahrel/indesign/batch_convert.html
Regards,
Uwe Laubender
( ACP )
// EDITED POST, BECAUSE LINK CHANGED.
thanks!!! but idml should be saved at same location where its .indd file is present, this script works on multiple subfolders but it creates all idml at single path
It's an option to save the output where the InDesign files are.
Regards,
Uwe
thanks!!! it works, just keep the target path as blank, output files get saved at the same path i.e of source file
Hi Uwe,
the link doesn't seem to work. Is it still valid?
Maja
Found it! Karel scripts have been migrated here:
https://indesignsecrets.com/peter-kahrels-script-repository-comes-to-creativepro.php
Hi Maja,
Regards,
Uwe Laubender
( ACP )
