• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Vertical green lines and horizontal blue line while rendering
New Here ,
Dec 08, 2016 Dec 08, 2016
Hi vlcsnap-4401-03-07-10h52m33s814.png@
I am quite an amateur user of after effects .
I started making a composition on after effects and while it was being rendered , two vertical green lines apeared and a horizontal blue one .When the render finished .The result was the two lines appearing in the video .
I think its a problem or a property with preview but i dont know exactly .
I am using after effects cs6 with i5 2.3ghz and 8gb ram
Hope to have an aswer ASAP
Thanks for your time ...
Views
3.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
cropping screenshots is never a good idea. there is vital information we are missing. show us the full Ae interface with all your layers. provide some details about your setup: is this a template? did you create this yourself? did this always appear? does it happen with a fresh project? what exact Ae version are you using (we need full numbers) and exact Os too.
Votes
Translate
Translate
Report
Report
LEGEND ,
Also, drill down into your precomps until you find the composition that contains those lines. Then find exactly what layer has those lines. Then find out what effect is causing those lines. Tell us what it is. (If it's a third-party plugin, you probably need to pay for it and license it.)
Votes
Translate
Translate
Report
Report
New Here ,
Ok guys thanks a lot for your advice .It doesnt need to share any more more information about the problem .The problem as you guessed was created by trapcode particular .Although i found the problem i wonder why particular causes that problem since i have used it a lot op times to make fields of particles 😕
Votes
Translate
Translate
Report
Report
LEGEND ,
Szalam called it seems the effect has got inactivated in your Ae version. try to activate it through the effect controls panel
Votes
Translate
Translate
Report
Report
LEGEND ,
Wait, it's Particular? I'll bet it's not a registration issue (that's a red x with Particular). I'll bet if you go into the Physics>Air>Turbulence Field settings you'll find the option to see the fields is turned on. And, I'll bet if you adjust the settings to move the particles based on the field, those straight lines will turn curvy.
Votes
Translate
Translate
Report
Report
LEGEND ,
Dec 09, 2016 Dec 09, 2016
I'd like to place my bet on Szalam's suggestion
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Jan 12, 2017 Jan 12, 2017
Hi Chris,
Did Szalam's answer work for you?
Kevin
Votes
Translate
Translate
Report
Report
Community Beginner ,
Oct 12, 2020 Oct 12, 2020
LATEST
Hi, had the same problem and Szalam's answer worked for me, I could kiss you!
Votes
Translate
Translate
Report
Report
