Hello Again,
I now need to switch the logic around from my previous question.
I have one dropdown field that I would like to appear dependent on the four other dropdown fields all answering Yes to their question.
Guessing I would have to run some kind of validation script, but not sure how to link them all together.
As Always Thank you
Something like this:
var b1 = this.getField("Dropdown1").value=="Yes";
var b2 = this.getField("Dropdown2").value=="Yes";
var b3 = this.getField("Dropdown3").value=="Yes";
var b4 = this.getField("Dropdown4").value=="Yes";
this.getField("Dropdown5").display = (b1 && b2 && b3 && b4) ? display.visible : display.hidden;
Bump
I would use the calculation script of a (hidden) text field to achieve this, instead of placing a script under each of the drop-down fields.
What might that look like?
I replaced the Dropdown selections with my field names tripled check for spelling errors but it isn't doing anything.
Is there something I'm missing?
var b1 = this.getField("Field 1").value=="Yes";
var b2 = this.getField("Field 2").value=="Yes";
var b3 = this.getField("Field 3").value=="Yes";
var b4 = this.getField("Field 4").value=="Yes";
this.getField("Field 5").display = (b1 && b2 && b3 && b4) ? display.visible:display.hidden;
Are there any error messages in the JS Console? If not, can you share the
file (via Dropbox, Google Drive, Adobe Cloud, etc.)?
On Fri, Dec 9, 2016 at 11:30 PM, chughes919 <forums_noreply@adobe.com>
Got it to work. Some complication on my end. Thank you for the script!
