1 Reply Latest reply on Dec 19, 2008 7:12 AM by Newsgroup_User
    Full Path of selected File
    KalemKutu
      Hi together,
      in our programming project we are facing a problem with handling of files.
      Due to the security it is not possible to handle local files via flash.
      This is what I figured out by searching via google.
      But is it possible to get just the full path of a user selected file?
      Scenario
      The flash file we are using is embedded in a local stand alone application,
      i.e. it is not on the server and also not embedded in html, php, jsp, ...
      User clicks on a button. A pop-up window displays the directory structure.
      User can navigate to a directory within local drive and select a file.
      Currently we only get the file name like process.pdf
      But we also want to have the full path like C:\Documents\Project1\process.pdf
      So we only need this full-path string. We don't want to do anything with the selected file with flash
      How is this possible, to get full file path with flash by using flex 3?
      Thanks a lot
      K.K.
        • 1. Re: Full Path of selected File
          Level 7
          "KalemKutu" <webforumsuser@macromedia.com> wrote in message
          news:gig89e$f1v$1@forums.macromedia.com...
          > Hi together,
          > Scenario
          > application,
          > the
          Sounds like you need to be using AIR
