0 Replies Latest reply on Dec 9, 2016 12:06 AM by adila72868579
    Android build error, plugins conflict
    adila72868579
      I have an error:
      Oh geez. Your build failed. Click the "Log" button above to view the compile log. If you need help diagnosing the issue, you can post to the support forum with your App ID (please do a search first).
      There are two plugins that conflict with each other:
      https://github.com/OneSignal/OneSignal-Cordova-SDK
      dariosalvi78 (Dario Salvi) · GitHub
      There maybe conflict in play service api.
      I tried to use older versions of plugins but it doesnt help.
      Earlier i build my app with this confit within any problems. But now i cant.
      Please help me, or give any suggestions.
      How can i set playservice version in config.xml ?
      Thank you
      APP ID: 1898352
      LOG:
      Build Date: 2016-12-08 12:32:11 +0000 Configuration on demand is an incubating feature. Incremental java compilation is an incubating feature. :preBuild UP-TO-DATE :preReleaseBuild UP-TO-DATE :checkReleaseManifest :preDebugBuild UP-TO-DATE :CordovaLib:preBuild UP-TO-DATE :CordovaLib:preDebugBuild UP-TO-DATE :CordovaLib:compileDebugNdk UP-TO-DATE :CordovaLib:compileLint :CordovaLib:copyDebugLint UP-TO-DATE :CordovaLib:mergeDebugProguardFiles :CordovaLib:packageDebugRenderscript UP-TO-DATE :CordovaLib:checkDebugManifest :CordovaLib:prepareDebugDependencies :CordovaLib:compileDebugRenderscript :CordovaLib:generateDebugResValues :CordovaLib:generateDebugResources :CordovaLib:packageDebugResources :CordovaLib:compileDebugAidl :CordovaLib:generateDebugBuildConfig :CordovaLib:mergeDebugShaders :CordovaLib:compileDebugShaders :CordovaLib:generateDebugAssets :CordovaLib:mergeDebugAssets :CordovaLib:processDebugManifest :CordovaLib:processDebugResources :CordovaLib:generateDebugSources :CordovaLib:incrementalDebugJavaCompilationSafeguard :CordovaLib:compileDebugJavaWithJavac :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.). Note: Some input files use or override a deprecated API. Note: Recompile with -Xlint:deprecation for details. :CordovaLib:processDebugJavaRes UP-TO-DATE :CordovaLib:transformResourcesWithMergeJavaResForDebug :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug :CordovaLib:mergeDebugJniLibFolders :CordovaLib:transformNative_libsWithMergeJniLibsForDebug :CordovaLib:transformNative_libsWithSyncJniLibsForDebug :CordovaLib:bundleDebug :CordovaLib:preReleaseBuild UP-TO-DATE :CordovaLib:compileReleaseNdk UP-TO-DATE :CordovaLib:copyReleaseLint UP-TO-DATE :CordovaLib:mergeReleaseProguardFiles :CordovaLib:packageReleaseRenderscript UP-TO-DATE :CordovaLib:checkReleaseManifest :CordovaLib:prepareReleaseDependencies :CordovaLib:compileReleaseRenderscript :CordovaLib:generateReleaseResValues :CordovaLib:generateReleaseResources :CordovaLib:packageReleaseResources :CordovaLib:compileReleaseAidl :CordovaLib:generateReleaseBuildConfig :CordovaLib:mergeReleaseShaders :CordovaLib:compileReleaseShaders :CordovaLib:generateReleaseAssets :CordovaLib:mergeReleaseAssets :CordovaLib:processReleaseManifest :CordovaLib:processReleaseResources :CordovaLib:generateReleaseSources :CordovaLib:incrementalReleaseJavaCompilationSafeguard :CordovaLib:compileReleaseJavaWithJavac :CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.). Note: Some input files use or override a deprecated API. Note: Recompile with -Xlint:deprecation for details. :CordovaLib:processReleaseJavaRes UP-TO-DATE :CordovaLib:transformResourcesWithMergeJavaResForRelease :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease :CordovaLib:mergeReleaseJniLibFolders :CordovaLib:transformNative_libsWithMergeJniLibsForRelease :CordovaLib:transformNative_libsWithSyncJniLibsForRelease :CordovaLib:bundleRelease :prepareComAndroidSupportSupportV42400Library :prepareComGoogleAndroidGmsPlayServicesAnalytics980Library :prepareComGoogleAndroidGmsPlayServicesAnalyticsImpl980Library :prepareComGoogleAndroidGmsPlayServicesBase980Library :prepareComGoogleAndroidGmsPlayServicesBasement980Library :prepareComGoogleAndroidGmsPlayServicesFitness940Library :prepareComGoogleAndroidGmsPlayServicesGcm980Library :prepareComGoogleAndroidGmsPlayServicesIid980Library :prepareComGoogleAndroidGmsPlayServicesLocation980Library :prepareComGoogleAndroidGmsPlayServicesTasks980Library :prepareComOnesignalOneSignal342Library :prepareProjectCordovaLibUnspecifiedReleaseLibrary :prepareReleaseDependencies :compileReleaseAidl :compileReleaseRenderscript :generateReleaseBuildConfig :mergeReleaseShaders :compileReleaseShaders :generateReleaseAssets :mergeReleaseAssets :generateReleaseResValues :generateReleaseResources :mergeReleaseResources :processReleaseManifest :processReleaseResources :generateReleaseSources :incrementalReleaseJavaCompilationSafeguard :compileReleaseJavaWithJavac :compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.). Note: /project/src/com/plugin/gcm/OneSignalPush.java uses or overrides a deprecated API. Note: Recompile with -Xlint:deprecation for details. :compileReleaseNdk UP-TO-DATE :compileReleaseSources :prePackageMarkerForRelease :transformClassesWithDexForRelease FAILED FAILURE: Build failed with an exception. * What went wrong: Execution failed for task ':transformClassesWithDexForRelease'. > com.android.build.api.transform.TransformException: com.android.ide.common.process.ProcessException: java.util.concurrent.ExecutionException: com.android.dex.DexException: Multiple dex files define Lcom/google/android/gms/internal/zzsd; * Try: Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. BUILD FAILED Total time: 6.661 secs Error: /project/gradlew: Command failed with exit code 1 Error output: Note: Some input files use or override a deprecated API. Note: Recompile with -Xlint:deprecation for details. Note: Some input files use or override a deprecated API. Note: Recompile with -Xlint:deprecation for details. Note: /project/src/com/plugin/gcm/OneSignalPush.java uses or overrides a deprecated API. Note: Recompile with -Xlint:deprecation for details. FAILURE: Build failed with an exception. * What went wrong: Execution failed for task ':transformClassesWithDexForRelease'. > com.android.build.api.transform.TransformException: com.android.ide.common.process.ProcessException: java.util.concurrent.ExecutionException: com.android.dex.DexException: Multiple dex files define Lcom/google/android/gms/internal/zzsd; * Try: Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.     at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)     at emitTwo (events.js:106:13)     at ChildProcess.emit (events.js:191:7)     at maybeClose (internal/child_process.js:877:16)     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
