1. Re: Button not showing up in Interactive PDF created through InDesign CC
BobLevine Dec 9, 2016 10:48 AM (in response to clausfrederiksen.dk)Did you export an interactive PDF? If so, what PDF reader are you using?
Screenshots might help.
2. Re: Button not showing up in Interactive PDF created through InDesign CC
clausfrederiksen.dk Dec 9, 2016 11:03 AM (in response to clausfrederiksen.dk)I think I found a workaround:
- I layout the form in Indesign.
- Then I open the exported file in Acrobat DC
- Then I add the final functionality in Acrobat DC
- And Voila: Everything works fine.
One advice: Don't open the file in Preview, as it probably holds the problems???
3. Re: Button not showing up in Interactive PDF created through InDesign CC
clausfrederiksen.dk Dec 9, 2016 11:17 AM (in response to BobLevine)Hi Bob // Why doesn't the PDF exported from Indesign work directly in Acrobat Reader? // It is surely a tedious business having to correct everything in Acrobat DC... // And the PDF doesn't work at all in Preview ;-( // At least not on my macs...
4. Re: Button not showing up in Interactive PDF created through InDesign CC
BobLevine Dec 9, 2016 11:57 AM (in response to clausfrederiksen.dk)Without seeing the files or knowing your complete workflow I have no idea.
5. Re: Button not showing up in Interactive PDF created through InDesign CC
clausfrederiksen.dk Dec 9, 2016 12:43 PM (in response to BobLevine)Hmm... It now showed that the form also didn't work in any browser on osSierra // I now got it working but only in Reader...
I'm a bit frustrated 'cause my client want it working from a webpage... // What to do?
c
6. Re: Button not showing up in Interactive PDF created through InDesign CC
BobLevine Dec 9, 2016 12:58 PM (in response to clausfrederiksen.dk)If you’re expecting it to work anywhere but Reader/Acrobat you’re going to be sorely disappointed.
If you need a form that works in a browser look at Google Forms. You might want to give this a read, too:
7. Re: Button not showing up in Interactive PDF created through InDesign CC
clausfrederiksen.dk Dec 9, 2016 2:30 PM (in response to BobLevine)Hi again Bob // I really appreciate your help ;-) // I'm thinking about making a HTML-form instead and putting it on my own server // Before I go about it, is it savvy to do it this way? //
c
8. Re: Button not showing up in Interactive PDF created through InDesign CC
BobLevine Dec 9, 2016 5:02 PM (in response to clausfrederiksen.dk)Sure. There are a lot of ways to create an HTML form for a website.
Bottomline is this: If your form needs to work in a browser, PDF is probably the worst choice you can make.
