I just installed LR 2015.8 and noticed that the Radial Filter and Graduated Filter both produce a color cast when applied. Even if all the controls are set to zero there is still a magenta cast. It is easiest to see in shadow areas of the images. This does not happen in LR 2015 6.1 Anybody else have the issue and know if there is a fix for it? Thanks.
What about the color effect color picker located near the bottom of each of those tools? Is it set to "No color effect"?
Right. That's it. A color was loaded and I didn't realize it. Thanks.
If you have the color picker set to something other than white, then that color will be applied as part of the filter. I'm talking about the color picker in both the gradual filter and the radial filter.
Yes, I get. I just update to 2015.8 a few hours ago and I don't remember turning it on so maybe it was defaulting to on and orange. It's a little hard to understand the amount of color cast you get when all the settings in the filter are at zero.
It's somewhat hidden. You have to set the bottom right slider to 0
