0 Replies Latest reply on May 18, 2006 1:43 PM by akiva.kent
    pass variables
    akiva.kent Level 1
      I want to pass a variable which will represent a filename to a swf file from a hypertext link in an HTML document.
      When the user clicks on the link which has ?variablename=filename_to_use appended to a "normal" link to a page,
      this variablename will be passed to the swf file.
      I've already created this target swf file to have an actionscript with a FLVPlayComponent with the filename hard-coded in the actionscript. I want the actionscript to use the variable representing the filename_to_use that was passed to from the URL line.
      The following is the actionscript that plays the flv file taken from the Flash Help: Creating an Application with an FLVComponent
      ORIGINAL VERSION:
      import mx.video.*;
      this.attachMovie("FLVPlayback", "my_FLVPlybk", 10, {width:320, height:240, x:100, y:100});
      my_FLVPlybk.skin = "file:///install_drive|/Program Files/Macromedia/Flash 8/en/Configuration/Skins/ClearOverPlaySeekMute.swf"
      my_FLVPlybk.contentPath = " http://www.helpexamples.com/flash/video/water.flv";
      VERSION USING THE FILENAME FROM THE PASSED VARIABLE INSTEAD OF WATER.FLV
      import mx.video.*;
      my_FLVPlybk.contentPath = " http://www.helpexamples.com/flash/video/variable";
      I currently can play videos with this actionscript at my school website but must make a separate swf for each video.
      I want to be able to have one swf file that will play which video was passed from the link in the HTML page.
      I am using HTML page to lower the bandwidth so that users won't have to load a swf file to see curricular material and then perhaps choose a video on the topic.
      http://www.wearekennedy.com/kent/whatsup.htm
      click the link to the Spring curriculum map with resources and then click on e.g. The_Food_Web video
      Thank you,
      Kevin Kent
      Educator, John F. Kennedy H.S., Bronx, NY
