3 Replies Latest reply on Dec 10, 2016 1:53 PM by Bob Somrak
    crop tool
    coreyb32939214 Level 1
      I find it hard to use this tool,  when I press R to bring up the crop tool that works but when I start to draw the tool it starts to double the size of the image I'm working on to 200%  .  The second issue is that it will not create the square box to the size I want ..
        • 1. Re: crop tool
          John Waller Adobe Community Professional & MVP
          Which version of Lightroom are you using?
          • 2. Re: crop tool
            JoeKostoss Adobe Community Professional
            In Lightroom, you do not "draw" the crop.  When you hit R, the crop is already there either on the edges of the original image or as last set by you.  You simply move the crop handles as you like, or place the curser inside the crop where it turns to a hand; you can then move the image inside the crop.
            There is no "Size" in Lightroom Develop Module.  Just set the crop to 1 x 1 and move the crop to where you want it.  Image size is set in the Export function.
            • 3. Re: crop tool
              Bob Somrak Level 6
              You CAN leftclick-hold and draw a crop box in Lightroom.  You DO NOT have to use the handles.  You just have to use the ASPECT tool which is automatically activated the first time you use crop but must be manually activated if you activate crop a second time on the photo.
