• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Scripts for glossary entries?
Explorer ,
Dec 11, 2016 Dec 11, 2016
In a document with a glossary, there are two labor-intensive but very repetitive tasks:
1) Making the word (in the glossary) as an anchor (= the word or term), so it can be the target of a hyperlink elsewhere in the text.
2) Finding instance of each glossary word in the main text and applying a hyperlink to it.
Since these are highly repetitive tasks, has anyone developed a script or scripts?
[CC 2017]
Views
654
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
It's a glossary!
Could you show a page?
Votes
Translate
Translate
Report
Report
Explorer ,
Here's a glossary page. The word or term has a nested character style and is demarcated by the space followed by en dash. (The definitions, obviously, are minimal, for school students.)
Online, I can make the definition pop up if the user hovers over the word in the text, or link to the glossary page.
Votes
Translate
Translate
Report
Report
LEGEND ,
Peter,
What final use?
When you click on the word in the current text, you want to have a pop-up? …
or do you want to jump to the concerned glossary page?
Votes
Translate
Translate
Report
Report
Explorer ,
This document will be published as a PDF.  (A few will probably print it, but that's not the intent.) It is not necessary to have a popup text when a user hovers on the word, but it would be a plus — if easy to do.
The same text & images will be used online, but pagination and some other formatting elements are too different to do it as an export from ID.
I should have said that a tech colleague says it's easy to have a pop-up definition on the website, but I don't know that myself.
Votes
Translate
Translate
Report
Report
Explorer ,
Oops — I talked about 'hovering' but you asked about clicking on a word in the text. Same basic answer —a popup could be a plus — but I was planning on it taking the user to the correct place in the glossary section.
Votes
Translate
Translate
Report
Report
LEGEND ,
Dec 12, 2016 Dec 12, 2016
Peter,
Last comment: Do you work on a single ID file or a book with several ID files?
[Have you already found a way to fix your issue?]
Votes
Translate
Translate
Report
Report
Explorer ,
I am the only person working on this file during this phase of the project. I may turn it over to someone else next month.
I don't have any way to create all the anchors and hyperlinks efficiently; I think I could create a script or two to do it, but I've never scripted InDesign before — I was hoping someone had already done a script or scripts that would only require a little modification to use on this.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Peter,
As I see on the screenshot [post#2], the page shown covers letters "E" to "O", that means 11 letters on 26!!
Is the glossary only running on 3 pages with ~ 80-90 entries! If we suppose 3-5 links per entry, we have a 240-450 range!
Manually doable!? 1-2 work days (working cool! and not too fast to avoid errors)
Votes
Translate
Translate
Report
Report
