• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
After Effects alerte: expression desactivate
New Here ,
Dec 11, 2016 Dec 11, 2016
Hi !
I can't apply une expression:position between an jpeg image and a Null Object.
After effects says:
Erreur : Object of the Layer was found at the place of a numeric value or propriety.
Can anyone help me ?
Views
228
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Dec 11, 2016 Dec 11, 2016
Any expression applied to a position property must return an array. From the little I can see of the expression in your screenshot it just points to a layer. I'm assuming there is a layer in the timeline named "Targget" and that you want to use some property in that layer. At the very least your expression should read: thisComp.layer("Targget").poisiton
You should study the After Effects expression reference and guide. You'll find it easily by typing expressions in the search help field at the to
Votes
Translate
Translate
Community Expert ,
You should study the After Effects expression reference and guide. You'll find it easily by typing expressions in the search help field at the top right corner of AE and following the links.
I'm also not sure but you may have to write some of the expression in the same language your are using in your OS.
Votes
Translate
Translate
Report
Report
New Here ,
Dec 14, 2016 Dec 14, 2016
LATEST
Thank you for your answer !
Later I found that I wasn't using the expression on the position of the Target, as you said, but just on the Target himself.
Votes
Translate
Translate
Report
Report
