• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Same raw,same monitor,new PC,different colour in LR,pls help!!
New Here ,
Dec 11, 2016 Dec 11, 2016
I had build a new desktop for photo edit,
but very big different colour with same RAW photos and same monitor in Lightroom,
the image are very flat and dead colour,
Anyone can help me???Thanks Thanks Thanks a lot!!!!
Here is the strange colour with my new PC(same monitor)
view?usp=sharing
This is the normal colour with my old PC(same monitor)
view?usp=sharing
Views
332
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Dec 12, 2016 Dec 12, 2016
Lightroom needs a working monitor profile to display correct colors.
Most other applcations don't use the monitor profile, and are therefore unaffected by a defective profile.
Try setting the monitor profile to sRGB as described below.
If this fixes the issue, you should ideally calibrate the monitor with a hardware calibrator.
Press the Windows key+R, type colorcpl, and hit Enter.
Add the sRGB profile, then set it as Default profile. See screenshot (from Windows 7) below.
Make sure that Use my settin
Votes
Translate
Translate
LEGEND ,
At a quick glance, it would seem that the old PC had a calibrated monitor profile while the new one does not.
Votes
Translate
Translate
Report
Report
New Here ,
Hi Joe,thanks for your reply:)
I didn't edit any monitor profile of two pc,
And i open the raw file was normal without LR,
E.g. window photo viewer,It was same with my old PC,
The dead colour problem only in LR only....:(
Votes
Translate
Translate
Report
Report
LEGEND ,
It could be that the monitor on the new computer needs to be calibrated. That should be the first thing you check.
With regards to your two screen captures, we can see almost all of the sliders in the develop module are at zero in the screen capture from the new PC, but we can't see where the sliders are on the screen capture of the photo on the old PC. Depending on what you did, the problem could also be that the photos was properly edited on the old PC, but the edits didn't transfer on the new PC.
Votes
Translate
Translate
Report
Report
New Here ,
Hi DJ,thx for your reply,
i think no need to calibrate the monitor or tune the driver,
because all the operation colour range are normal,like gaming or movie,
the dead colour problem is in LR only compare with same raw files,
and those photos are non edited form my wedding job,just read in to LR
Votes
Translate
Translate
Report
Report
LEGEND ,
Some applications use the monitor calibration profile, and some don't. So you can see nice colors in some programs, and the monitor still needs to be calibrated because other programs that do use the monitor calibration profile show poor colors. So you definitely should calibrate the monitor on the new PC.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Make sure that Use my settings for this device is checked.
Votes
Translate
Translate
Report
Report
