4 Replies Latest reply on Jan 17, 2017 5:01 PM by Kevin-Monahan
    Black and slow preview on Composition
    HOKORITA
      Hi all, i've an issue on After Effects CC 2017.
      After i close the project for the first time and open it again when i start the preview i see all my composition black, and the rendering previews doesn't work properly anymore.
      Is not a large project, i used 4-5 videos and i used only "timewarp" effect.
      I can't resolve this problem, i need to work with after effects, i can't do it with black preview always...
      i can't see ANYTHING except BLACK, and this happen only when i re-open the project.
      This problem was the same on CC 2015
      I tried:
      -Disable all effects on videos
      -Magnification zoom fit 100%
      -Change preview quality
      -Update GPU drivers
      System info:
      - Windows 10
      - AMD FX-8350 @ 4.0GHz
      - Sapphire Radeon R9 285 Dual X
      - RAM 8GB x 2 @ 1866MHz
      Pls help me, i don't know what to do...
        • 1. Re: Black and slow preview on Composition
          Roei Tzoref Adobe Community Professional
          let's try to isolate this problem. if you open a fresh project with a new composition and create some layers like solid, text and shapes - does it appear black too? how about importing a video file other than the ones you have in this project which .Avi which is an unpopular video that is usually related to a exporting mistake and seem suspiciously related to your problem - where are those files from? give us more information and we might be able to help you. this may be a codec problem.
          • 2. Re: Black and slow preview on Composition
            HOKORITA Level 1
            When i create new solid layer when i press "ok" my GPU crashes with After effects...
            Never happened!
            I tried to reinstall my GPU drivers but same problem, crash when i create solid layer.
            No, it works fine.
            I tried to import an mp4 file, i put it on the composition, but when i try to preview won't work and is blocked, but if i drag the time indicator i can see something on preview, only if i drag obviously... if i stop drag it stop.
            The videos come from a game that called AVA (Alliance of valiant arms) and i can record inside the game, when i stop he generate an AVI file that i'm using in my project.
            • 3. Re: Black and slow preview on Composition
              sounds like a codec problem. I am guessings videos play fine in VLC player... Make sure you have quicktime installed (just the essential components) and try a different video file. Download a youtube video using a free online youtube downloader like keepvid or something. Record you screen using other export settings. You can also convert your videos using VLC player. If you have a codec pack installed then try to remove it.
              • 4. Re: Black and slow preview on Composition
                Kevin-Monahan Adobe Employee
                Hi Hokorita,
                Have you solved this problem yet? Let us know.
                Kevin
