0 Replies Latest reply on Dec 11, 2016 7:46 PM by noodles2000
    After Effects Codec Subtype Name
    noodles2000 Level 1
      I am currently creating an importer plugin and it generally works fine, however when using it in After Effects - if you highlight an imported file in the properties section for the file it shows the codec as 'FRQU'  which is the FOURCC for the FlexresQuality codec that I have created the importer for.
      I implemented imGetSubTypeNames selector, however it only ever calls it passing in the FOURCC of the file type ('FLEX') and not any of the sub codecs that I have (FLEX is the FOURCC of the file wrapper, like Quicktime and FRQU is the FOURCC of one of the many codecs that can be used inside a Flex wrapper)
      I also tried to register every codec inside imGetIndFormat but that did not work.
      Is there something that I am missing ?
      Nigel
