Hi there,
I can no longer select text in the standard layout view; instead, the text frame itself moves.
Please see the below for a screen-captured example:
I can still select and edit text in the Story Editor. I'm not sure if I've accidently enabled a setting, or what. I would much appreciate the ability to be able to edit text quickly in the Layout view.
Cheers, and thanks in advance for any advice / help!
iMac 12,1 (Mid 2011)
macOS Sierra 10.12.1
InDesign CC 2017 (12.0.0.81)
FIXED
Somehow, the behavior has returned to normal. I'm still unsure what happened, but the problem started with a specific file; upon deleting preferences, then closing and reopening that file, I was able to select text again in the layout view (across all files).
Very strange; I hope this was simply a minor bug, and that this post helps resolve the problem for others. Cheers!
Wow. Not good. Why don't you start by deleting preferences?
Troubleshooting 101: Replace, or "trash" your InDesign preferences
Is it just that one file?
If it’s only this file, I would export to IDML. No sense trashing prefs for one corrupt file.
FIXED
Great! I'm glad deleting preferences fixed it for you!
