13 Replies Latest reply on Feb 12, 2018 8:58 PM by Bob Somrak
    Metatags in Filename Template Editor only insert at the end instead of at cursor.
    Bob Somrak Level 6
      In the Filename Template Editor you can place your cursor anywhere is the edit dialog.  Text typed at the cursor will be placed where the cursor is at.  The problem is if you pick one of the metatags and hit INSERT the metatag IS NOT placed at the cursor but at the end.   This makes editing the template very difficult as you essentially have to redo the whole template from scratch.  This happens in both import and in the rename in library.  This is a changed behavior in 2015.8.  Using OS X 10.11.6
